I do believe I got bit by my purchase...
A 750 Edelbrock ? I'm not so sure they did on this motor.
That's kinda what I was curious about...I think maybe he offed some parts (intake and carb) when he sold the boat. So "unknown" upgraded cam that's a part of 527/570 dyno event then is now part of a 750cfm carb creates what kind of limitation/danger?
Just a lament, but when I got into powerboats I asked around and found the most recommended mechanic and he knew nothing about the #30 bypass filter, and missed a ton of other specifics. He was a good parts changer though.
A 500+HP motor should be spinning a 23p prop at minimum so a 19p isn't encouraging. A 750cfm seems small for a warmed up BBC. My internet guess that whatever engine is in there is putting out 375-400hp at most.
I saw a CL ad from 2010 that states the boat ran in the low 70's...I was only able to hit 58 mph in the brief time I have had it. Thanks for the continued help...
Ok, the plot thickens...the PO also had some really expensive 4-blade stainless prop but wasn't included in the deal. I think he wanted more than $500, maybe $800 for it. Maybe the 19p mirage is the stock one for the OEM 454 mag? Would the boat maybe benefit from a prop change?
What ratio is your drive?
If its a standard 1.5 and you were doing 58 with a 19 pitch prop, your tach was probably starting to smoke,,,
with a 1.5 gear in a smaller boat and a 23p prop 58 is around 4400 rpm
So what kind of speedo and how accurate?
given an avg prop slip of 12% or so 58 on a 19 pitch is about 5500 rpm.
So if your spinning 5500 rpm its probably not going any faster because your may be sitting on the limiter... if the engines built for it, if not your boat may not be the only thing floating.
You need to try a 23p because by the math is seems like you have been running the car floored in second gear wondering why it wont go faster.
The boat's tach has never been over 5k the couple times I've tested it...maybe it's not too accurate . I did check my speedo vs gps app on my phone and it was pretty close. Maybe that's the cause of banging. I'll get the VC's off tomorrow and see if anything broke.
No, it's the original Bravo One drive (I have the tag) w/ 1.50 ratio.
