I do believe I got bit by my purchase...
#41
#42
Screw that, if you paid for a comp. test and got results as if they did it I'd force them to buy the boat from me for the price I paid for it. Someone would be taking that POS back from me especially if I had a written bill of sale documenting all of the parts that were supposed to be included that the seller removed. Lawyer up!
#43
I'm going forward with an autopsy and rebuild...leaning more toward reliability vs. performance if necessary. Not knowing IF the crate motor has the correct oil filter by-pass, I will order the correct one(s). I've read some varying answers even on this site. So including the part# for the correct 30# bypass valve...to encourage more (not all) oil through the filter...can someone show me the parts shopping list for a Gen VI 502 block? I want to hand them to the engine builder and rule out that possible repeat mistake. Is it one or two valves? I'm assuming I won't need to force all oil through the filter. Finally, I most recently used the Napa Gold 1060 filter...was that ok? Thank you.
#44
#45
So is gm part #******** (edit/25161284) (30#) all I need to swap in??? Do I need one 30# bypass valve for the oil cooler line, also?
#46
and once again which bypass valves go in & at which location? I assume none of these bypass valves are at the remote filter location? IS this correct: at the block location: remove the center return bypass completely & install the 30# bypass @ the side (outlet) location (which currently feeds my filter 1st). I know I'm starting to talk like Trump .
#47
Pretty much everything that you need to know is right here.
http://www.offshoreonly.com/forums/g...-hardware.html
Cooling the oil before or after the filter is debatable but not an engine killer.
#50
I have seen that valve part #25013759 described as the oem 11lb. valve AND part #25161284 as the correct 30lb bypass...No wonder so many builds get jacked?!
