Winterization question >
Old 10-04-2002 | 01:36 PM
bcoffield's Avatar
Registered User
Default Winterization question
Does anybody remove the speedometer tube from the back of the speedometer and blow through the tube to expel any water in it? or is it nothing to worry about?
bcoffield is offline
Old 10-04-2002 | 03:03 PM
blown formula's Avatar
By Jove!! That's one I never thought of!! It should not be a problem. When the boat is on a trailer, gravity flow should pull any/most of the water out. Also, the water is in a rubber tube ant there is plenty of expansion to not hurt anything as far as I can see. my .02
blown formula is offline
Old 10-04-2002 | 03:30 PM
bcoffield's Avatar
Registered User
Dam! Here I thought I found a way to get the wife involved in the winterizing process.
Old 10-04-2002 | 03:43 PM
pb's Avatar
pb
You can get your wife involved...she can go refill your cocktail when required.
pb is offline
Old 10-10-2002 | 03:41 PM
cgarrett's Avatar
Default Water in Speedo tube
I'm dealing with older manuals but it states to "remove tubing from speedometer fitting and blow through tubing to remove water"
Cordell
cgarrett is offline
Old 10-10-2002 | 03:46 PM
Brad Perry
We got too much time on our hands..........
better drill about a dozen small holes in the trailer frame, there might be some trapped water in there too. Haven't you ever heard of all the unfortunate boaters who have craked trailers come spring? Or cracked speedo tubes...
Old 10-10-2002 | 03:48 PM
Wally's Avatar
Were doomed!
Getting water out of the line should not be an issue unless you have a leaky gauge or a hole in the speedo line somewhere......the speedo gauge is basically an air pressure gauge. It works by the water pressure compressing the air in the line and giving you a reading on the gauge.
Nice avitar by the way!
-Wally
Wally is offline
baja bailey
07-20-2008 07:24 PM
Sea Ray 200
03-19-2007 07:57 AM
Donzi26ZX
5
10-16-2006 02:40 PM
gripit
8
12-22-2004 02:26 PM
BajaBuddy
5
10-04-2003 10:55 AM
