Who wants to play >
Who wants to play
Who wants to play
Old 12-16-2016 | 08:29 AM
  #141
bump comp to where it should be 10-1 / real carbs as in size / real intake / cam # s will come up different guaranteed / may be even keep exhaust , be exciting to see stainless marine as in Tims ran against gen 3 or sky is the limit exhaust
hotrodford is offline
Old 12-16-2016 | 08:32 AM
  #142
marine exhaust not headers
Old 12-16-2016 | 08:39 AM
  #143
marine exhaust does not want to edit
Old 12-16-2016 | 09:17 AM
  #144
I mentioned earlier where a marine engine builder had ran a set of stainless marine exhaust like tims, up against dyno headers, power dropped from about 640hp, to 600hp with the stsinless marine exhaust installled. I believe it was a 502ci build.
MILD THUNDER is offline
Old 12-16-2016 | 09:18 AM
  #145
what tails were on them?dia size
sutphen 30 is offline
Old 12-16-2016 | 09:30 AM
  #146
You ALMOST had it man. The 741 is the winner. However, once I advanced it 4*, it lost.
The 741 Cam, made the most AVERAGE power, from 3500 to 6000rpm.
Wasn't it a tie at 568hp between the 741 and the 168801 (same spec but on a 110lsa)? Only mentioning because I said the 168801 (d)...
Mr Maine is offline
Old 12-16-2016 | 09:39 AM
  #147
you lost by 1ft/lb of torque.you'll still get a trophie,,everyone does here.
Old 12-16-2016 | 10:15 AM
  #148
F-2 Speedy's Avatar
How much total timing was in the 741 pull ( winner )
F-2 Speedy is offline
Old 12-16-2016 | 10:40 AM
  #149
Your typical 4" tail with 3.5" ID inner pipe ..they were the std length risers if i recall
Old 12-16-2016 | 12:07 PM
  #150
That's pretty significant. I'm surprised as I've heard the Gen3 SM are good for 800hp? Or is it because the dyno headers are dry?
Baja Rooster is offline
