Bandit motors >
Bandit motors
Bandit motors
Old 01-03-2017 | 12:31 PM
  #31
Full Force's Avatar
Crazy huh? Haha
Originally Posted by MILD THUNDER
Yea, the 651 is 244/256 on 114 LSA. Your cams, are 241/246 112 LSA. Also, you have a 4.25 stroke 540ci. Not shocking that this engine is making power to 6200, and yours was dead at 5500. And your peak torque was much earlier.
Full Force is offline
Old 01-03-2017 | 12:35 PM
  #32
vintage chromoly's Avatar
Cam in the 512 we did:
vintage chromoly is offline
Old 01-03-2017 | 02:32 PM
  #33
https://www.youtube.com/watch?v=yDO2h6d_3l0&feature=youtu.be Video of the old Kurt Marine guys from back in the day. Hatches broke loose, zero fuks given, just kept on going
MILD THUNDER is offline
Old 01-03-2017 | 02:35 PM
  #34
How did that dyno? What heads?
Crude Intentions is offline
Old 01-03-2017 | 02:47 PM
  #35
I'm sure we could have hit 700HP if we were shooting for a "dyno" number.
Turn down the oil PSI, bump up the timing and dial up the crankcase vacuum and I bet we would have pulled 700.
Brodix bb2 plus heads. Ported and CNC chambers.
Last edited by vintage chromoly; 01-03-2017 at 02:50 PM. Reason: Added cylinder head info
Old 01-03-2017 | 03:16 PM
  #36
How come it starts real rich and leans up the whole way. Mid 13s is a little on the lean side like close to melting pistons isn't it?
Old 01-03-2017 | 03:41 PM
  #37
The AFR was derived using an air flow meter and a fuel flow meter. No O2 sensors, so the AFR is somewhat suspect. We pulled plugs after a couple different pulls and they looked good (strap and porcelain).
We called dale cubic who does our carbs and the decision was made to leave the carb be until we can fine tune it in the boat with an O2 sensor in each header.
Old 01-03-2017 | 10:48 PM
  #38
https://youtu.be/55_zfmocVIM
chancer540 is offline
Old 01-04-2017 | 04:14 AM
  #39
https://youtu.be/S7oWahfIxUo
I'CE is offline
Old 01-04-2017 | 04:57 AM
  #40
SB
The AFR was derived using an air flow meter and a fuel flow meter. No O2 sensors, so the AFR is somewhat suspect. .
Not somewhat suspect. This method never works even for semi-close A/F numbers.
SB is offline
