Blower surge Make it stop >
Old 01-16-2017 | 01:39 PM
MT can post a video of before and after his Daytona sensors installation showing the improvement on his carbed blower engines. It is nothing short of dramatic.
Eliminated572 is offline
Old 01-16-2017 | 01:53 PM
Havasubill, what carbs do you have
Edit: jist reread and saw you have 830cfm holleys. Pretty sure those are the old school carbs. No adjustable idle feeds in those if i recall.
But, you can try experimenting with some small wire, V shaped, inserted into the restrictor in the metering block, to reduce some of the fuel flow.
MILD THUNDER is offline
Old 01-16-2017 | 02:05 PM
with timing locked dont think any curve will cure it, just for grins try removing and plugging the power valves just to test and see what it does, might be enough vac fluctuation to cause them to act weird, also 8.5 ??? are they boost referenced carbs ?
ezstriper is offline
Old 01-16-2017 | 02:25 PM
I am looking for more surge. Wanna trade for a 177/Dominator setup?
79formula is offline
Old 01-16-2017 | 03:07 PM
Registered User
Mild Thunder thank you do much for your advice, its nice to see some have positive input on a post. Im just exhausted trying everything to cure this. So when I dumped the timing to 10 at idle and lean it out I can get it to idle at 850 but as soon as I put a load on it, it will die. So Im wondering if a different profile of cam will help this at all? Ive done over 40 blower engines and have never had one that I cant tune the surge out of. So just pulling my hair out as Ive spent lots of hours and never get anywhere with it stopping. So some what in a nut shell ive tried the lower timing and adjusting the carbs for that and it still reacts the same.
Eliminated thanks for the info on the Daytona I went and checked it out and looks like some good stuff to have even if I didn't have this issue.
havasubrian is offline
Old 01-16-2017 | 03:10 PM
Registered User
So Mild thunder your stating that if I had the timing come back in gear they wouldn't die when shifted? Curious as to once I would do that I would be back to surging and hard to get out of gear?
Old 01-16-2017 | 03:16 PM
Registered User
Eliminated572 I would love to see that video please if you can find it. Im wanting to find something that will blow me away with a fix!
79Formula have you got two of them or one? I would need two. Before I end up in a rubber room making surge noises! LOL
Old 01-16-2017 | 03:19 PM
Registered User
EZstriper been there and done that blocked off. They are boost reference and for sure they are not opening as the vac never drops below 11 pounds. They are defiantly closed!
Old 01-16-2017 | 03:22 PM
I only got one. I cant pump up the power anymore anyways. Id have the broken bravo blues with anymore power.
Old 01-16-2017 | 03:28 PM
Registered User
79Formula Im having to be careful as Im 850HP @ 5500 and Im bravo ones with Imco shotys! That is why I want the surge gone so I can drive the stupid thing! Thank God its not a customers boat LOL
