another cam thread >
another cam thread
another cam thread
Old 02-01-2017 | 06:52 AM
  #41
Mike, Found this. Relative build to what you have going on. 454 with AFR 265's and crane hyd roller
http://www.hotrod.com/articles/crane-cams-dyno/
MILD THUNDER is offline
Old 02-01-2017 | 12:41 PM
  #42
articfriends's Avatar
Originally Posted by vintage chromoly
Hey lee.
FYI:
Check those crower EDM lifters real closely!
I just bought a set last spring / late winter and one was absent the EDM hole.
I had to send it back and get a replacement.
Probably just a fluke, but just a heads up.
I bought a set of flat tappet crower edms for a Pontiac a few years ago and one of them looked like bottom was finished with a 36 grit air sander and I think one was missing edm hole, their QC inspector has to be blind and retarded.
articfriends is offline
Old 02-01-2017 | 07:40 PM
  #43
Hey Mike, I did a Mk IV 454 jet boat engine a few years ago with the 741, AFR 325 cnc chamber heads, single plane intake,9:1 compression and 850 carb. It pulled a solid 600 HP at 6000 RPM on the dyno(didn't pull it past 6000). So I would think you would be just about the same.
Bob
com
[QUOTE=mike tkach;4524876]after doing some research i decided to go with a crane 168741 cam.in this small 462 cu in engine i think it will pull hard to 6400 or so and still have more low end grunt than the car can use]
bobl is offline
Old 02-01-2017 | 07:59 PM
  #44
that,s good to know bob,i think it is going to have a nice power curve with the 265s.just wondering why you went with the 325s.
mike tkach is offline
Old 02-01-2017 | 08:12 PM
  #45
SB
So who won ? I don't feel like doing the math to see who was closest ? And what's the prize ?
SB is offline
Old 02-01-2017 | 08:51 PM
  #46
looks like you are the winner,pm me your address and the prize will be in the mail.
Old 02-01-2017 | 08:53 PM
  #47
2 others were also close so i guess the prize get,s split up three ways.
Old 02-01-2017 | 09:25 PM
  #48
SB
SB is offline
Old 02-01-2017 | 10:33 PM
  #49
Figured you'd have that question...LOL Remember a jet boat only has about a 1000 rpm operating range at WOT, so low end doesn't matter at all. It was also about availability at the time. I personally don't think a smaller head would have made more HP, but definitely a much better torque curve. I sure hope to see a dyno run with those 265 heads though!
Bob
bobl is offline
Old 02-01-2017 | 10:44 PM
  #50
the owner is willing to spring for a dyno session but the place that has done my machine work&dyno time is having some issues and i am not sure where to go for a dyno day.
