Stainless marine to stellings width issues? >
Old 02-02-2017 | 11:46 AM
Your height would be more of an issue. I just set a dart 4150 on with 4150 carb and the with a 3" spark arrestor puts your near even across.
getrdunn is offline
Old 02-02-2017 | 12:36 PM
Full Force's Avatar
That was another thing to look at
Full Force is offline
Old 02-02-2017 | 01:28 PM
F-2 Speedy's Avatar
I put raised port AFR's on my 540's bravo application with CMI's and the pipes lined up fine, no cutting at all
F-2 Speedy is offline
Old 02-02-2017 | 04:37 PM
Panther's Avatar
Frank's Marine Service
Thinking about running used headers? Please don't!
Panther is offline
Old 02-02-2017 | 04:49 PM
Full Force's Avatar
depends who I would get them from, I have a buddy that can fix anything needed, but I can tell you NEW are not in d=budget at this time, if I wait till next winter then yes, new...
not even sure what brands are good and for TRS
Old 02-02-2017 | 05:11 PM
Your were fortunate cause darts just don't line right up. I witnessed it first hand with Gil's anyway. Exhaust holes at transome as well as center to center.
getrdunn is offline
Old 02-02-2017 | 05:16 PM
Just gotta take a little precaution and pressure test and keep up on them. I'm going to be running stellings that came from a friend on OSO and have no problem with it. the ones I posted in pic Tim the tails pretty much go straight back.
getrdunn is offline
Old 02-02-2017 | 05:52 PM
The problem with used headers is even after pressure testing you don't usually find a problem until after they fill your cylinders with water. I had a set of tested headers on mine that filled the #5 cylinder two months later. Luckily it didn't turn over and do any damage.
I would keep your manifolds knowing that they may be holding the engine back and spring for new headers when possible.
Baja Rooster is offline
Old 02-02-2017 | 06:05 PM
Originally Posted by Baja Rooster
The problem with used headers is even after pressure testing you don't usually find a problem until after they fill your cylinders with water. I had a set of tested headers on mine that filled the #5 cylinder. Luckily it didn't turn over and do any damage.
If buying new I'd definitely buy KE's or SS Gen lll's. You might as well forget about headers all together.
getrdunn is offline
Old 02-02-2017 | 06:21 PM
I agree with Panther, I would think long and hard about used headers. Maybe your buddy can fix anything, but if they need to be fixed once, IMO they are junk. It's only a matter of time when another leak will spring up. If you don't catch it in time, good by new engines!
I am the one that getrdunn witnessed having to modify the transom. I went form 088 heads to Dart Pro 1 heads and I had to move my exhaust holes up and out 1/2" to 3/4". I run Gil thru the transom, dry to tip pipes. The chance of running a raised port head, and having thru the transom pipes work without modification IMO is ZERO, unless the pipes were built for that set up.
endeavour32 is offline
