low compression 548 dyno testing has begun!! >
Old 02-14-2017 | 05:52 AM
  #71
Originally Posted by articfriends
My carb guy norm says ssme thing, 4150 modded to flow same as dominator will out perform it in every way BUT i would think 3 or 4 hp here or there, 25+?
It's all about the signal the carb see's and how it effects the fuel drawn out of the boosters, I have seen video(can't remember where) of camera's in carb on dyno pulls where you see the fuel coming in, and showing different intakes/spacers/carbs very interesting..keep up the great work !
ezstriper is offline
Old 02-14-2017 | 05:54 AM
  #72
Originally Posted by Tinkerer
SO - does an EFI gain from having a spacer. I have the HOLLEY 2000 CFM throttle body ( 4500 )
I dont think EFI will be effected anything like a carb with a spacer, as you are only changing airflow, not how the fuel is being drawn from the carb...
Old 02-14-2017 | 08:11 AM
  #73
SB
Alot of crazy schit going underneath carb's.
https://www.youtube.com/watch?v=7Iq1B-2paCs
SB is offline
Old 02-14-2017 | 10:20 AM
  #74
Cool video thanks for sharing
offshorexcursion is offline
Old 02-14-2017 | 11:44 AM
  #75
I second that !!
phragle is offline
Old 02-14-2017 | 12:11 PM
  #76
Chaos! Lol
I imagine similar pulses in the exhaust side which makes understanding reversion even easier.
Baja Rooster is offline
Old 02-14-2017 | 12:45 PM
  #77
kinda what I saw, but was from top of carb looking down, both really show weird stuff going on...
Old 02-14-2017 | 05:21 PM
  #78
offthefront's Avatar
popcorn ....... I love your threads .....
offthefront is offline
Old 02-15-2017 | 07:32 PM
  #79
articfriends's Avatar
Finally had a chance to get back to this, made a couple pulls tonight first pull established a baseline for today, same day same Dyno of course check timing check valve lash over previous good runs. Controlled the shop conditions until correction factor was almost dead identical to the other day made a baseline pull, horsepower numbers almost identical to last Saturday. Added a second inch of spacer under the Dominator gained four horsepower, lost 10 foot pounds of torque numbers look like s*** with this Dominator on there. Borrowing a box stock 1050 Dominator off a customer's race truck we have at our shop going to make a couple pulls with it when I get time in the next few days then I'm going to bolt the modded 4150 back on
articfriends is offline
Old 02-15-2017 | 07:56 PM
  #80
F-2 Speedy's Avatar
If I sent you one of these, would it be worth a test
Attached Thumbnails low compression 548 dyno testing has begun!!-20160923_133823.jpg
F-2 Speedy is offline
