low compression 548 dyno testing has begun!!
#61
We dynoed my engines with no spacer, open spacer, 4 hole super sucker, and ended up with both the 1" open AND the 1" 4 hole on my Foxwell ported Victor Jr. And a 1190 Prosystems dom
#62
Unless this dominator is a mess it seems it needs more spacer, we will know tomorrow. Im going to bolt the 4150 and its 3" of spacer back on and see if we get our hp back too!
#64
cool, let me see if I can send over next 2 days
Im moving on to efi after i get everythi g out of this that it can make, probably sometimes next week. If you can send me your carb and FA this week ill test it before moving on. You can find my address on our fb business page smittyseng or on our website contact page : smittysengtrans.com
#65
Smitty, I think what you are seeing is what a lot of drag race guys found a while back, the 4500, with a spacer/adapter to 4150 shows a strong signal to the carb and works very well, I know a few guys swear by this setup...
#66
Big block in general, if they need a DOM, tend to like a Dom manifold too.
#67
My carb guy norm says ssme thing, 4150 modded to flow same as dominator will out perform it in every way BUT i would think 3 or 4 hp here or there, 25+?
#68
Last year , a friend had dynoed with dominators. First one was a modified one from Nickerson. They tuned it on the dyno. It had a good afr from 4000 to 6500, but below that, it was all over the place. Tons of changes to the carb, and they werent happy with it. They put on a box stock ultra gen 3 dominator, made a couple jet changes , they had a rock sollid afr from 3200-6500, and picked up about 18hp if i recall at peak.
I think booster style can play a big role in the fuel atomoization. Straightleg, downleg, annular, etc.
#70
