Engine power question N/A motor >
Old 02-21-2017 | 08:56 PM
Smitty's Avatar
Default Engine power question N/A motor
Here are the numbers : At 5100 RPM, you have 586 HP and 606 TQ. Out of the norm right ? HP peak is at 5100 RPM. I always thought TQ should be less at peak HP. So what kind of results should I see in the boat ? Twin engine heavy V.
Smitty is offline
Old 02-21-2017 | 09:11 PM
when you had it on the dyno what rpm did you go to?
mike tkach is offline
Old 02-21-2017 | 09:21 PM
Your peak hp was probably at 6,100-6,500
getrdunn is offline
Old 02-21-2017 | 09:39 PM
Smitty's Avatar
Went to 5500 limiter. Hp was dead flat from 5100 to 5500. Ran out of airflow due to heads.
Getrdunn---in first post I stated peak was at 5100.
Smitty is offline
Old 02-21-2017 | 09:48 PM
SB
At 5250rpm HP and Torque cross on the charts since at this rpm torque=hp no matter what engine. So typically, under this rpm tq is greater than hp.
SB is offline
Old 02-21-2017 | 09:49 PM
articfriends's Avatar
Hp and tq are equal at 5250 on all gas engine dynos, if not dyno was screwd up, the "other" Smitty
articfriends is offline
Old 02-21-2017 | 09:50 PM
Lol, you answered at same time i did!
Smitty's Avatar
My question is how will this motor perform in a boat application ?
Smitty is offline
Old 02-21-2017 | 09:55 PM
SB
On a typical 4 cycle gas engine, HP peak rpm will be 1200 or so rpm after Tq Peak Rpm. I said typical. LOL. Unless limited by fuel, air/spark/valve control/or etc
SB is offline
Old 02-21-2017 | 09:56 PM
SB
I'm going to venture a guess that this engine has a 502MPI intake or some other tuned port intake ?
SB is offline
