Lifter madness >
Lifter madness
Lifter madness
Old 03-22-2017 | 04:04 PM
Originally Posted by Baja Rooster
Huh. It's a Gen VI GM ZZ502 build. I didn't have a super close look at them but at a glance I was surprised to not see them.
Dog bones is the stock setup. Tie bars is what the major aftermarket ones have. Allows for more travel especially with a taller lifter
Crude Intentions is offline
Old 03-22-2017 | 06:24 PM
Originally Posted by phragle
Gen 6. Hyd roller... I am understanding I cant run the stock lifters with .610 lift, what do I need???there are 50 million different hyd roller lifters and its all rather confusing....
Your not alone here so don't feel bad anyway. Remember the simple hyd flat tappet days? Simple and inexpensive to boot.
getrdunn is offline
Old 03-22-2017 | 06:46 PM
everybody has recommendations, but Im also looking for the whats and whys so I understand what it is I need.....
phragle is offline
Old 03-22-2017 | 07:31 PM
I stand by my recommendation... apparently I'm not alone!! lol
adk61 is offline
Old 03-22-2017 | 09:40 PM
Is that a stock height body, meaning no push rod length change
Edit: I just looked it up......+.300
Its really not the body height that you need to worry about , its the pushrod cup height, and the base circle of the cam, that will dictate whether or not a change in pushrod length will be needed.
MILD THUNDER is offline
Old 03-22-2017 | 09:49 PM
Originally Posted by snapmorgan
That is the same kit that I use. Eddie Young told me that as long as the top of the lifter doesn't fall below the dogbone on the base circle and as long as it doesn't hit the dogbone at max lift, that they will work fine. I installed a set on my 575SCI 4 years ago and 160 hrs ago and they are working fine. Couldn't ask for them to be more trouble free. Now, the guys at Bullet cams told me that about 400# spring pressure is all that they can handle. Might be accurate, might not be.
i have also heard that 400 over the nose is max,any more and the lifter will start to bleed down.imo the factory dog bone lifter is good until around 5200 rpm,after that the required spring pressure will cause lifter bleed because of the internal valving.
mike tkach is offline
Old 03-22-2017 | 09:52 PM
The real question, isnt what will physically work and fit clearance wise. Well, it is first and foremost, but all hydraulic lifters are not created equal, from a performance standpoint. The main reason many guys years ago, went to morel lifters , was because of their rpm ability. Today, guys are running hydraulic rollers in excess of 7000rpm. A gm lifter just isnt gonna get that done. To sustain 7000rpm, you need spring pressure. The stock valving in the GM lifters, will likely start giving up and bleeding down much sooner than say a morel, or johnson. A good real world test, would be to heat the oil to 200 degrees, and then do some back to back pulls with each style of lifter. Theres a good chance, the aftermarket lifter will show power gains. Also, while the GM lifter might do fine on a mild lobe profile, they might really start giving up when the lifter acceleration rates get up there.
The other benefit was going to a larger roller wheel diameter. Just like going to 55mm or 60mm cam cores, .903 or even larger body lifters in aftermarket blocks, all to keep pushing the envelope further on what the valvetrain can accomplish without destruction.
With that being said, you have a mild setup, and the GM lifter should work just fine. There is a reason the high end lifters cost what they do, and the GM lifters cost what they do.
Old 03-23-2017 | 07:51 AM
Just installed a .610 lift EFI cam in my new 502 block with the stock GM lifters and see no issues with either the bottom or top clearance with dogbones. Stock worked fine with that lift in my last 502 build and it ran to 5900 rpm with no issues.
LT1GMC is offline
Old 03-23-2017 | 08:29 AM
F-2 Speedy's Avatar
I talked to Travis @ E Young marine yesterday about one of my lifter plungers being fairly easy to push in, he wasn't much concerned about it with bleed off, so he told to me to prime the engine and see how it looks, we talked about the springs on my heads and said if they have a single blue marking they are the pac springs and replace them, well they are suppose to be almost new and they have no markings, Ive used some isky 8005a springs on some other heads and he said that's what they use as a replacement spring on the 525 head....so I really don't know what spring I have other than the machine shop said they all tested good.
F-2 Speedy is online now
Old 03-23-2017 | 06:29 PM
So I am looking at
Crane 13532-16
Crane 26535-16
and Comp 854-16
anybody ever use any of these??
phragle is offline
