Prop shaft depth >
Prop shaft depth
Prop shaft depth
Old 04-19-2017 | 04:34 PM
Default Prop shaft depth
What is the general rule gor propshaft depth on twins. Is it measured directly below outdrive or below the pad or "v" in the center of the boat.
mggdoors is offline
Old 04-19-2017 | 05:23 PM
I believe you put a straight edge on hull so it hits the bullet of the drive and measure down from there.
dereknkathy is offline
