Belhousing coolers. >
Belhousing coolers.
Belhousing coolers.
Old 07-26-2017 | 09:57 PM
Ok, you are running a very similar set up. It also looks like you're running boxes as well. How are your transmissions mounted to the stringers. If you don't mind, next time you are in your boat, would you mind snapping a few pictures of them?
endeavour32 is offline
Old 07-26-2017 | 10:03 PM
bck's Avatar
bck
Charter Member#568
No boxes. The rear motor plate is mounted between the bellhousing and block. I can take a quick look and see what kind of room there is. Give me a cell # for sending pics if that's an option, posting here is a bit of a pita
Straight bottoms and flat decks
bck is offline
Old 07-26-2017 | 10:39 PM
the old style plate that goes between the engine block and bell housing should work, it has holes in it, that should work to plumb the dual cooler.
1. top mount starter pad on the bell housing needs to be machined 1/4 inch for tooth engagement.
(some come that way, i have 1 of each but w/o coolers)
2. engine/bell dowels need to longer ( trans to flex plate alignment
Attached Thumbnails Belhousing coolers.-sany0363.jpg   Belhousing coolers.-sany0364.jpg   Belhousing coolers.-sany0365.jpg
outonsafari is offline
Old 07-27-2017 | 05:40 AM
old swap shop ad. looks like the cooler plumbing would hit that mount. http://www.offshoreonly.com/forums/s...flexplate.html
dereknkathy is offline
Old 07-27-2017 | 07:18 AM
here is my cell- 847-754-0335
Thanks!
Old 07-27-2017 | 07:19 AM
That is the bell housing that is on my boat now.
Old 07-27-2017 | 09:19 AM
And it looks like that mount won't clear the fittings...
Old 07-27-2017 | 11:08 AM
bck's Avatar
bck
Charter Member#568
As mentioned above, keep in mind that as you're mixing and matching these parts you might be changing starter and trans shaft engagement depth.
bck is offline
Old 07-27-2017 | 11:24 AM
Got them, Thanks
Old 07-27-2017 | 11:53 AM
bck's Avatar
bck
Charter Member#568
I completely changed the wording of that last post after I got your text...
bck is offline
