headers for 502's? >
headers for 502's?
headers for 502's?
Old 08-29-2017 | 09:02 PM
You couldn't run the engine off the dyno cooling system and feed the exhausts with a garden hose? It isn't like it is gonna be a half hour full power run.
dereknkathy is offline
Old 08-29-2017 | 09:15 PM
SB
Subject of this discussion is You want to run the engine fully dressed for a dyno run right ? For full wet exhaust, water can have impact on power and tune up and you can test for reversion. For dry exhaust with water running thru it for cooling only, I guess you could.
Edit in: Oh, and yeh, you run it for a bit to get coolant and oil temps up to where you would run it in the boat....so having water go thru the exhaust this whole time can add up.
SB is online now
Old 08-29-2017 | 09:20 PM
Originally Posted by MILD THUNDER
I'd have to argue with that rooster man. Standard stainless marine manifolds, have got their azz handed to them quite a bit on most modern marine N/A BBC builds. Mark from MER Performance had a mild 509 on his dyno this spring, that dropped 40hp and 35ft lbs of torque across the powerband by bolting on stainless marines vs his dyno headers. 40hp is a good amount in my book. Epecially when the power gains are throughout, and not just at peak.
Those GIL/Stainless marine/imco/EMI types of exhaust are more like comparing a shorty header to a long tube in the car world.
If I had to buy new exhaust, and didnt want the problems associated with stainless headers, I'd get these
Thunder-N-Lightning Cast Aluminum Exhaust Headers :: Thunder & Lightning Headers :: Exhaust Systems :: Diamond Performance Parts
My experience consist of working on one ski boat under a tree behind a trailer park, so argue away, Thunder Man!
But we haven't even discussed what cam it has! Lol!
Baja Rooster is offline
Old 08-29-2017 | 10:18 PM
There are a few guys that can accommodate wet exhaust on a eddy current dyno.
At least there used to be .
One had the hot water going out through 2 pipes going through the wall , other , in cali , had a door that opened up to the outside parking lot . (Those were later, after hours pulls)
airjunky is offline
Old 08-29-2017 | 10:27 PM
Well i pan on buying a set of the thunder n lightings manifolds for my 548 that just came off t dyno last week....
They clearly out perform some headers that are out there on the market.
I have heard of boats installing the thunder n lightings with gains of 2-3 mph with no other mod....
Anybody have any Drew Marine Shotgun mufflers for sale ????
chancer540 is offline
Old 08-29-2017 | 10:49 PM
Those Thunder and Lightening headers that MT linked to look really slick when painted/powder coated.
MT, where those big HP losses on the original SM manifolds or the Gen3 units? I'll be exhaust shopping next year as I feel my repaired CMIs are on borrowed time.
Old 08-30-2017 | 01:18 AM
I would look into the pricing on the CMI Fusion (Unitop) headers. One piece E-Top header with no joint. I had them on my Pantera.
They are made for standard Bravo exhaust exit locations.
Griff is offline
Old 08-30-2017 | 11:03 AM
one mention of the dyno and thread got derailed. so, eichhoma, you are considering headers. why? you have gils currently. do you anticipate upgrading the engines to where the gils will be too restrictive? or are you happy with power and durability you now have, and intend to keep the engines as-is?
Old 08-30-2017 | 12:52 PM
Its been a very informative and helpful thread....I am being told my Gil dry exhaust is on burrowed time... getting lots of steam, am being told that the flanges are not sealing well and that I should consider replacing when I pull it all this winter for some other work.... im not convinced it needs to be replaced yet. No major upgrades planned... in fact considering freshening some things up and selling it next year to move on to something else. I admit I like the look of headers if there is some performance in crease (guessing minimal at best) but it also looks like headers would save me a lot of curse words when I am changing the plugs too. The thunder and Lighting set looks very interesting... if I need to go that route
eichhoma is offline
Old 08-30-2017 | 01:19 PM
I love my E-tops. There was a very noticeable difference in the jump from 3000 to 5000 rpm time over iron manifolds and you can easily hold one with one hand.
ph1971 is offline
