Best mechanical fuel pump for 900 plus sc engine >
Old 02-10-2018 | 09:02 PM
  #51
Originally Posted by snapmorgan
Using Holley 12-845 regulator, installed just like diagram 2A in the install guide. -10 to the pump, -8 to regulator and carbs, -8 return. Holley tech support is of no help.
Did you instal low pressure sender and dash warning light. Cheap insurance. Set from factory at 3 psi
getrdunn is offline
Old 03-15-2018 | 07:19 PM
  #52
convincor's Avatar
Those running a mechanical pump what are you running for a fuel pump push rod?
bronze tip? Roller? Assuming you're also running roller cam.
convincor is offline
Old 03-15-2018 | 07:31 PM
  #53
I use a bronze tip with baker pump. No problem in 100hrs.
PPlay33 is offline
Old 04-03-2018 | 11:03 AM
  #54
cv products sell a great block mount fuel pump good with e 85 but its a little costly. Around $400 i believe
badbug is offline
Old 04-03-2018 | 03:09 PM
  #55
Panther's Avatar
Frank's Marine Service
The Holley billet pumps and regulators are also nice. Used them on the past 4 engines and liked them a lot.
Panther is offline
