Holley Sniper EFI
#32
you could open the unit up,cut their ecu out and then wire in a holley,,pita yes,,could it be done,sure,why not.
#33
#34
That’s no different then a carb with a wideband set up. I installed my wideband last season to see if the sensor would survive before moving to FI and so far all is good. I installed the sensor at 12oclock on top of the collector and using the innovative heatsink to help protect the sensor as well.
#36
#38
Since everyone is discussing O2 sensor replacement and no one has posted this solution I will.
A company called Performance Fuel Injection Systems makes an O2 plate that bolts between the manifold and the riser and fits a standard threaded WBO2 sensor. They have them for all engine makes and they mostly sell them on Ebay for about $85 with gaskets just search Ebay sellers for "performancefuelinjectionsystems". They'll work on any EFI system out there: Holley, FiTech, their own conversion, etc.
Michigan Motorz also sells an O2 adapter flange.
Now we can all go EFI
