Retarding cam - help reversion? >
Old 11-08-2017 | 03:24 PM
Just wanted to make note I'm not certain timing events are the same for gen VI cam 169651 as one listed above. One above is 139651 non step nose. I would imagine they are but...
getrdunn is offline
Old 11-08-2017 | 05:39 PM
Originally Posted by getrdunn
Been around for many years but stil a great cam and I bet would work well with your current build / heads. I'm not sure what your plan is to do but thought I'd post the cam card anyway.
That would be a good cam for his application if it wont revert.
still is going to have to prop the boat for 4800-5000 rpm.
And both the numbers have the exact same timing events just one is a step nose and the other is not.
Warship2k15 is offline
Old 11-08-2017 | 06:15 PM
sent you a pm
Old 11-08-2017 | 06:23 PM
same cam except for nose.
mike tkach is offline
Old 11-08-2017 | 06:57 PM
651 should pull peak 5,700-5,800 easily in a 540.
getrdunn is offline
Old 11-08-2017 | 07:12 PM
I assumed they were but you know what assumption can be remember? The mother of all fk ups. Mike you've used the 651 in several builds. What's typical peak hp in a 540 +/-? Also is there known reversion issues with wet exhaust. I wouldn't think it would but I'm not certain as I've never used it.
getrdunn is offline
Old 11-08-2017 | 07:16 PM
Better yet Mike whats the torque difference between 5000 and 5700.and please take into consideration the 088 heads and wet exhaust.
And yes please educate us on if it will revert.
Old 11-08-2017 | 07:18 PM
i never used a 651 in a n/a engine but in my blown 548s if i remember correctly they peaked around 6400 rpm.
Old 11-08-2017 | 07:22 PM
i think the torque curve was pretty flat,they made good torque from 4000 on up.i am to lazy to go to the shop to look at the dyno sheets,also i was not worried about reversion due to dry exhaust.
Old 11-08-2017 | 07:50 PM
You don't prop to peak torque if that's what your refeering to... well you can but will be a total turd.
getrdunn is offline
