Best EFI System for Big Block Chevy- 1200hp+ >
Old 12-04-2017 | 04:12 PM
  #31
14 apache's Avatar
Originally Posted by turbos230
Trying to get the 1200 hp with a engine that will run on pump gas from the regular gas station none of that racing fuel here.I dont have a choice of heads just something with great flow.
One thing I am trying learn more about is the compression ratio I need for this build, should be less than 10 or 9.5 for a procharged engine making about 8-10 boost.
Do you build your own engines? I don't think 9.5 with a blower at 8-10lbs is going to work to good.
14 apache is offline
Old 12-04-2017 | 04:18 PM
  #32
14 apache's Avatar
Originally Posted by hogie roll
Normal valve angle brodix, not SR20
They where 24* BB3XO 33? worked over by chad Don't know what they flowed after work.
Old 12-04-2017 | 05:58 PM
  #33
GPM
Ran my 598 with Dart, home made efi tunnel ram, dual 1200 cfm throttle bodies, 9:1, M4 and M5, seemed to do OK.
GPM is offline
Old 12-04-2017 | 06:10 PM
  #34
any pics of your set up
sutphen 30 is offline
Old 12-04-2017 | 06:26 PM
  #35
GPM
I'm not a paying member so I can't post any pictures.
GPM is offline
Old 12-05-2017 | 02:33 PM
  #36
Yes, Ok but why do you say that?
turbos230 is offline
Old 12-05-2017 | 08:58 PM
  #37
Panther's Avatar
Frank's Marine Service
Becase your effective compression ratio will be very high and into race fuel territory.
https://www.rbracing-rsr.com/compression.htm
Panther is offline
Old 12-06-2017 | 03:04 PM
  #38
GPM
I did my engines back in 02 to 06, broke some parts learning, ended up a bit more than 1200hp, I think it would be easier to make HP now with the improvements that have been made on cylinder heads. I still wouldn't use Chinese parts other than a last resort. Best of luck to you.
GPM is offline
Old 02-23-2018 | 03:22 PM
  #39
Ok I have the short blocks ready now and the heads are next, but thinking about what my solution will be on the injection.From reading here the HP EFI and Dominator are the 2 options holley offers with multiport injection like I want.Waht is the difference between the HP EFI and Dominator , different software one has better quality? How to decide
Old 02-23-2018 | 07:56 PM
  #40
The HP is plenty for Marine use, and probably the more common one. It will do anything you need in a boat and more. The dominator has more features and the ECU is physically bigger. The Additional features are mostly auto based, Line lock, fans, shift points, stuff that you would never need on a boat. I had probably the most complete Holley HP marine set up there is, and I never ran out of things to geek out on. Good luck.
launchpad475 is offline
