Howard's cams >
Howard's cams
Howard's cams
Old 01-04-2018 | 06:35 PM
Theres some new stuff out that isnt in here, but theres still plenty to look at.
http://www.compcams.com/Technical/Ca...terCatalog.pdf
MILD THUNDER is offline
Old 01-04-2018 | 09:19 PM
TomFTM's Avatar
I have used Howard's cams cast hyd. Roller cams in a few lower hp builds with good success .
TomFTM is offline
Old 01-05-2018 | 07:03 AM
F-2 Speedy's Avatar
As much as these engines cost to build or rebuild, isn't a 100 bucks foolish not to spend..............If its a 350 for an 86 suburban go cast and put the hundo in the tank
F-2 Speedy is online now
Old 01-05-2018 | 08:08 AM
all the cam,s used by gm now are billit steel.
mike tkach is offline
Old 01-05-2018 | 11:28 AM
even the factory cam in my old 97 454 dually is billet . I don't even think it has 100 lbs of seat pressure
Old 01-07-2018 | 02:47 PM
I just wanted to bring it up that their standard firing order hyd rollers are cast yet their 4/7 swaps are billit. Just seems odd. My last custom comp billits were very nice however curious about Howard's. The 100.00 difference in billit over cast core I honestly think I spent in beer last night. I'm feeling the pain today trust me.
getrdunn is offline
Old 01-07-2018 | 02:50 PM
Originally Posted by MILD THUNDER
Landis LT1VE capable of profile accuracy to .00012 , and up to 70mm cam cores. 100% american made cores. Howards Cams has also purchased a new Adcole 911-36NT for checking accuracy of this increased production. The 911-36NT allows for measurements up to 36 inches in length with an accuracy of 0.0001 micron and 0.001 degree of resolution
Comp cams has probably the most extensive line of BBC hydraulic roller and solid roller lobe profiles I have seen. But generally speaking, most of the typical lobes are available from all the big cam companies. Crane, Comp, Lunati, Howards, etc.
Comps endurance specialist is David McCarver. If you're interested in talking to him, I can text you his email address.
If you have his direct number would be great. Tks
getrdunn is offline
Old 01-07-2018 | 03:15 PM
F-2 Speedy's Avatar
You need a billet core because the single swap and double swap are easier on the valve train............but Im no cam expert
Old 01-07-2018 | 03:44 PM
Think about what you just said. Lol.. Dont matter anyway cause I will have billit regardless.
getrdunn is offline
Old 01-08-2018 | 06:40 AM
F-2 Speedy's Avatar
it was a play on your post......
