Donzi Classic 18 upgrade >
Old 01-14-2018 | 02:12 PM
Default Donzi Classic 18 upgrade
Wanted to thank many of you for your words of wisdom, technical capability and warnings while I did my "ground up on my Classic 18 2+3. .....Now that I've had it on open water, I've realized I want a little bigger boat. I like the rough water handling of the Donzi, but its a little too small...and while only intended on inland lakes (around 55mph), I'd like to pursue more.
Thinking I'd like to run about 100 mph ish...single engine...I think a Donzi Classic 22 will get me there, but don't like the look of the larger Donzi's and am thinking I need 24 feet or so....is there a boat about 25-26' length that you would recommend?
sandslot is offline
Old 01-21-2018 | 10:31 AM
Bump... thoughts?
sandslot is offline
Old 01-21-2018 | 11:34 AM
GPM
25 Daytona, 26 DCB
GPM is offline
Old 01-21-2018 | 05:43 PM
rak rua's Avatar
Not 100mph but with the 300's, it would be a very nice ride.
(If you like the simplicity of low maintenance outboards)
25 Sportdeck Outboard for sale: no power
RR
rak rua is offline
Old 01-26-2018 | 05:45 AM
Originally Posted by GPM
25 Daytona, 26 DCB
This or many other quality cat/tunnel designs in the 25-27 foot range.
i might be selling mine if you are interested.
you would be hard pressed to get a donzi 22 in the high 70s let alone 100 mph.
They are good boats but get unstable at higher speeds and would need an extreme engine to push it to those speeds..
Great boats but just not designed for what you are looking to do.
Warship2k15 is offline
Old 01-26-2018 | 07:14 AM
A 525 got my 22 Classic solidly in the 80s and i regularly boat on Great Lakes. I personally know of two that run over 100 and many that are in the upper 80s and lower 90s without insane power. However the Donzi Classic is not for everyone.
thirdchildhood is offline
Old 01-26-2018 | 10:41 AM
Understand your points. To be more specific, I’d like to have a 100-mph boat but probably wouldn’t drive it there.... but big water like the Great Lakes is of interest and not look out of place when on an inland lake (where i live)... so thinking Classic 22 but I’ll look at the ones you mentioned... and if selling yours email me at [email protected]
sandslot is offline
Old 01-27-2018 | 08:02 AM
Sandlot. I’m not a mechanic nor engineer. So what I’m saying is not gospel. It would seem to me that you are setting yourself up for disaster. A 23 ft boat doing 100 on Lake Michigan. Something has to give. Dozi Iss a fine boat but there are areodynamic limitations that you need to consider. It seems that is just too small of a hull to do what to want. Especially on big water. I would suggest that you consider a little larger and then have fun.
All the best
3pointstar
t
3pointstar is offline
Old 01-27-2018 | 01:33 PM
Buy Will Smiths 30' Phantom and be done. Great rough water boat. And in the right conditions easy over a 100mph
class6 is offline
Old 01-27-2018 | 06:41 PM
I agree with class6... I owned a 30 phantom and boat on lake Michigan. It will meet your requirements plus they have great lines imo. My old boat is also for sale, and runs 100+ I can put you in touch with the owner if your interested.
obsessed1 is offline
