Question re: MSD 6m-2L / blaster ss Ignition problem >
Old 06-22-2018 | 02:17 PM
it does but the breaker was not tripped... im working through the troubleshotting on their website... I have 12V at the red wire coming to the MSD box... I guess I need to look at the distributor next
eichhoma is offline
Old 06-22-2018 | 02:24 PM
BBYSTWY's Avatar
That would be my next move...pull the cap and rotor and there should be a module under there...I had a MSD "billet marine" distributor in my boat before my rebuild and was having ignition issues at the end of last season and when I pulled the cap I'm pretty sure I found the problem...the whole ignition module in the distributor was a solid chunk of rust lol...needless to say I bought a new distributor for the build lol...Like I said swap that out of the other engine and hopefully she'll fire up!! if so...I would replace them both as if one failed the other one can't be far behind it!! just my opinion
BBYSTWY is offline
Old 06-22-2018 | 05:04 PM
so, I think I found the problem... removed the distributor cap and this is what I found....
some additional debris in the bad one.... I assume its toast....
And here's what the other one looks like.... The "good" one....
So is it safe to say I need a couple new distributors??
eichhoma is offline
Old 06-22-2018 | 07:30 PM
SB
So how many years has the MSD ,Marine distributors been horribly rusting and they haven't changed a thing ? 20? 25yrs ? More ?
My Sparks Disappeared
L\Do a search, MildThunder found a CRC spray that keeps corrosion away from inside these distributors. If you choose to stay with Many Schit Distributors.
SB is online now
Old 06-23-2018 | 05:09 AM
BBYSTWY's Avatar
I went with all star brand dist from Lane automotive here in Michigan....similar design to the MSD but a fraction of the cost and theyre billet with I think better quality looking guts....Who makes a true marine dist?? Daytona??
And yes I would replace both dist if I were you bud...glad you found the problem!!
BBYSTWY is offline
Old 06-25-2018 | 09:59 AM
MSD now has an anodized distributor but that may not solve their problem. I've had it with MSD. I'm replacing the ones in the Formula this winter with DUI and the Hustler to if they'll clear the blower.
payuppsucker is offline
Old 06-25-2018 | 10:47 AM
SB
Anodizing the distributor body has nothing to due with the quickly and heavily corroding weights, screws, magnetic pick up assembly,etc........
SB is online now
Old 06-25-2018 | 10:50 AM
Agreed..........
Old 06-25-2018 | 01:02 PM
Further venting (put a vacuum fitting in one of the brass screen holes, then route the line to a fitting on the flame arrestor) the cap may be a solution....similar to what GM did with the later optispark distributors on LT1's. That way fresh air is pulled through it continuously and it can dry out.
SS496 is offline
Old 06-25-2018 | 01:37 PM
SB
In case people missed this as it appears some did. ^^^
Many Soon Die
SB is online now
