Water dumps
Old 08-28-2018 | 12:12 PM
  #31
You said you have the regulator set to the lowest rate...........meaning you have it screwed all the out.....counter clockwise?
payuppsucker is offline
Old 08-28-2018 | 12:28 PM
  #32
yes.thats where i get the most water
warlocky is offline
Old 08-28-2018 | 12:32 PM
  #33
The most water coming out of the dump or relief port?
Old 08-28-2018 | 12:43 PM
  #34
only exit i have are the exhaust and one dump with the relief value
warlocky is offline
Old 08-28-2018 | 12:49 PM
  #35
You said gauge is pegged.........what's the range of the gauge? 0-15, 0-30, 0-50?
Old 08-28-2018 | 12:55 PM
  #36
0 to 35
warlocky is offline
Old 08-28-2018 | 01:00 PM
  #37
There has to be a blockage somewhere. You still have the dumps off the rear of the intake?
Old 08-28-2018 | 03:17 PM
  #38
no.The only restriction i can think of is the s pipe is to close to the end of the riser causeing a back up kinda.everything is clear.i think i saw some deals you block off some of the holes on a bravo to decrease the water intake to help this sence my lower unit is so deep in the water
warlocky is offline
Old 08-28-2018 | 03:32 PM
  #39
You shouldn't need to do that with the relief valve. At what speeds/RPMs are you seeing the excessive pressure?
Old 08-28-2018 | 04:10 PM
  #40
mid to wot
warlocky is offline
