LS Build: In Progress >
Old 03-18-2019 | 06:46 PM
  #161
Originally Posted by 242LS
You almost want to go straight to a museum so it doesn't get dirty. Beautiful.
BTW - Does anyone have the dyno sheet/numbers for a stock Merc 330 or 420? I'd love to see how the torque numbers compare.
Heres a sheet from a GM crate 454HO . Should be fairly
close to a merc 420. Also a LS3 crate. Similar hp, different torque curve for sure.
MILD THUNDER is offline
Old 03-18-2019 | 06:47 PM
  #162
Btw. I will be doing a b testing on the coolant system. Both are setup with 160 thernostat. One has 2 holes drilled. One has 3. I will be running them monitoring temperature stability and water pressure when we do get out and about. Figured it would be a good idea so people know what to expect when the give this a go
mggdoors is offline
Old 03-18-2019 | 06:51 PM
  #163
Dirty. That would be my gto currently. Redoing turbo plumbing at the same time as this build. Its a f******ing mess right now
mggdoors is offline
Old 03-18-2019 | 07:09 PM
  #164
I was looking for the 310-330 torque numbers earlier... Merc seems to keep those closely guarded for some reason....
phragle is offline
Old 03-18-2019 | 07:25 PM
  #165
I took MILD THUNDER's 454HO chart, eyeballed the actual numbers and plotted against my LS3 and 509/AFRs/cam (the LS looks just fine for torque now):
242LS is offline
Old 03-18-2019 | 07:30 PM
  #166
The LS3 crate is 10.7:1 static, where the 454HO is 8.75:1. I can see where the big block would shine , in the lower rpm and acceleration department.
Suprised the 6.2L LS3 doesnt make more torque, a 6.4L hemi makes around 475ft lbs.
Old 03-18-2019 | 08:15 PM
  #167
Rookie's Avatar
Nice numbers.
I personally will not build high RPM boat engines again. To achieve my PK HP and speed I was spinning my engines ~6500 RPM that pushed my "legit" cruise speed to 5000 RPM's. There was never a real balance in prop pitch selection. Either spin the s#it out of them with a small wheel or load the engines with a bigger prop. Engines ran great, but running engines 6000+RPM's for miles that you hand built with your hard earned money just makes your guts pucker.
Rookie is offline
Old 03-18-2019 | 09:24 PM
  #168
14 apache's Avatar
be carful plastic hose on wastegates it will melt off if you run it hard enough at least in a boat it will. Came back from a ride in my vdrive and nothing was hooked up and making big boost. Lo
14 apache is offline
Old 03-18-2019 | 10:14 PM
  #169
never had an issue in her. Been like that 7 years. I could see an issue in a boat with a much longer duration of high rpm. Longest this has ever been wot was texas mile run.
mggdoors is offline
Old 03-18-2019 | 10:24 PM
  #170
Originally Posted by Rookie
Nice numbers.
rpms on the ls engine is not an issue given you keep it reasonable. As I stated in a previous post I will be chopping these guys off at 6200 even if they make more power past that. Luckily I built mine to plateau right around my mark. With mine being a cat my cruise speed is still pretty damn high. We are setting her up with 32 cutting edge 5 blades with added cupping from trailing edge to the tip and 1.5 pitch bravo. Very low slip at cruise and wot. At 4k we should be 65-70 according to how these props ran last year for slip numbers. Now in my dominator I could see where your getting at.
mggdoors is offline
