LS Build: In Progress
#421
Sounds like you need to lower the X and shift the CG rear ward somehow. Is there anything up front you can take out? You’re now riding on a CG that’s moved so far forward it may be on the wrong side of your center or pressure on the hull. Combined with the stern being so much higher in the water now, you don’t have any drive or skeg in the water.
#422
#426
You need more women on the back bench. Problem solved and you are welcome.
i know less about cats next to my knowing almost nothing about twins, but it does seem like your ass end is trying to climb up and swap places with the from.
If this was originally a single is there a pod down the center?
It may be worth filling up some 5g buckets of sand and moving them around until you find the sweet spot, but it does sound like you need deeper or different props.
#427
#428
Started thing about the scenario. Idling in gear the boat does not go straight well either. I am thinking I have a possible air in steering case, which makes sense considering the boat drives like a willys jeep with a loose steering box
#429
Checked steering play in off position. 8” when applying heavy pressure. Lol. Purged air. 1/16”. I think that explains the steering wherever it feels like. Found out drivers trim cylinder is not retracting fully as well. At least not consistently. Will rebuild them tomorrow. Did the other side last summer.
