LS Build: In Progress >
Old 03-03-2021 | 07:29 PM
  #521
Originally Posted by sutphen 30
what computer did you use?
Holley Terminator on these ones. Also run Dominator on another build. Both are excellent
mggdoors is offline
Old 04-11-2021 | 08:00 AM
  #522
Any updates on how it ran in your boat
Bajaorlando is offline
Old 04-11-2021 | 01:08 PM
  #523
Not yet. Should be on water in 30 days or so. Just finished cut and buff below rub rail on paint job. Another week-week and half for top then back together she goes. Literally polished/powdercoated/reupolstered etc everything in boat. Full resto.
mggdoors is offline
Old 07-01-2021 | 04:16 PM
  #524
Originally Posted by mggdoors
The lt4 is a different beast than mine. It is direct injected with a higher compression and heads that flow 50cfm more out of the box. The lt4 supercharger will not work on ls applications due to wrong port match and no injector bosses. This dyno run is at 148kpa/7.1psi boost. Had belt slip which you can see in posted dyno log. It is cable driven throttle. We are using the factory intercooler modified with gusseting to prevent collapsing it under sustained load. Cooling is raw water ran through an iron ly6 block no thermostat. If you go aluminum block you will have to go closed cooling because block temp must rise to I would say 160 to allow bearing clearance to grow otherwise you will dstroy engine. We should see upwards of 9psi when belt slip is corrected which will easily push us over 800. Yes it is 1.9 tvs. Keep in mind that I am barely using the potential of this supercharger. With a lower pulley change we could be upwards of 16-18psi. But would require e85
are you running raw water through the inter cooler?
Hot Rod 29 is offline
Old 11-04-2021 | 08:39 AM
  #525
I will build a stock LT1 Gen.V in my 29ft Velocity VR-1.
Only 460 HP but the VR-1 is a light weight hull.
I hope it´s enough power for cruisin.
What do you think?
neuer_Typ is offline
Old 11-04-2021 | 08:52 AM
  #526
What do you think?
I think you better run closed cooling or you will murder the mains when the aluminum block fails to heat up and expand the bearing clearances. Otherwise its a great engine. I personally would do an l8t. You get an iron block which is only a few more pounds but you get a long stroker 6.6L. A cam swap would be easy 550hp
mggdoors is offline
Old 11-04-2021 | 09:34 AM
  #527
What ever happened with this project?
Wildman_grafix is offline
Old 11-04-2021 | 09:51 AM
  #528
life. Its all finished up. Just havent had time to take it out. We went straight from that to my GTO repaint/ tremec tkx swap/ etc to my yard on my house. In the last month I built 1400ft of pipe fence, laid 4000sqft of grass, and about 200 tons of rock/dg. Finishing that up currently. I will update when we get it out. Maybe after holidays.
mggdoors is offline
Old 11-04-2021 | 10:42 AM
  #529
Yes, i will run a closed cooling system!
I´m in germany....no chance to get a 6.6L.
But....it would be a nice project....if i need 800hp+
Old 01-28-2022 | 10:48 AM
  #530
if you were to build this more for a midrange torque and go NA and no stroker kit, would 317 or even 243 heads work well instead of the LS3 which I believe like higher revs? trying to spec out my 6.0 NA build for small lake boat but want good get up for ski.
Derek Iwasiuk is offline
