MSD distributor failure >
Old 06-28-2019 | 09:11 PM
Tinkerer's Avatar
It looks to me like it wasn't properly engaging the ring gear.
Look at the wear marks.
Tinkerer is offline
Old 06-29-2019 | 06:49 PM
My MSD dist. and box are also seven years old and have been nothing but perfect. I change the springs, cap and rotor and spray with CRC once a season. Lucky so far I guess.
ph1971 is offline
Old 06-29-2019 | 09:08 PM
SABER28's Avatar
no they were not. the bendixes were not popping out all the way. these starters probably started the engines less than 25 times to do this, btw.
replaced them with tiltons and have not had problem since. and they admitted to me they had issues with those starters.
SABER28 is offline
Old 11-01-2023 | 06:24 PM
Originally Posted by cdowjr
I’ve had 2 new MSD 83606 mechanical distributors fail on my engine! What’s wrong here?
What do you recommend for another brand?
Cliff in maine
MSD is caca
I am going back to OEM or I will try Pertronix
johnnys1957 is offline
Old 11-02-2023 | 09:58 AM
Originally Posted by johnnys1957
MSD is caca
I’m currently just running the pertronix distributors mag PU and a coil. Ya I’m going to install my cd’s sometime soon as I have them new in the box but just a fyi current set up is flawless
getrdunn is offline
Old 11-02-2023 | 12:16 PM
Default MSD = Lucas “prince of darkness”
Cliff in maine
I wonder if your MSD units are “Chinese Knockoffs” of “Chinese Knockoffs” manufactured on the graveyard shift. My biggest issue with MSD is the corrosion issue. I will be ordering MSD replacement springs and weighs to replace the rusted units. Otherwise I’m buying a used Mercruiser OEM distributor as a replacement
Old 11-02-2023 | 12:45 PM
F-2 Speedy's Avatar
MSD = may soon die
F-2 Speedy is offline
Old 11-02-2023 | 06:11 PM
MSD = may soon die
Agree 100%. I just had a “new” coil go bad on the Mach 1 but what’s crazy is the ign box etc still up and running from back in the 80’s. The dist lasted a half dozen spins around the block and the coil lasted 12.
Tells you that they’ve gone china! Might as well just buy the cheap knock offs. The mag pick ups are identical fyi.
getrdunn is offline
