Crownline 225 CCR 454 MAG is slow!!!
#53
It just won't benefit you any to spin it that fast. The horsepower peak is around 4800, beyond 5000, you are losing hp.
A camshaft change to something with more duration will shift your power curve to a higher rpm if that's what you want.
#54
A 454 Mag won't blow up at 5500 rpm.
#56
Ok
sorry for the miss information I thought you had a 454 MPI 385 hp I gave you the heads up because that's what I have and I went thru the same thing, same size boat w/454 MPI Mag 1997 Baja Boss 25.2
then you should do well with the 24p 4blade(Bravo1) if not the rev4 21p but you are any where in between a 4 blade and a 3 blade ,the 25p I still think your are over pitched, with the four blade you'll loose 1 or 2 miles per hour but a lot more stability, hole shot etc.
I wish luck !!
James
I wish luck !!
James
#57
Ok
I wish luck !!
James
I wish luck !!
James
#60
There are all sorts of "boat speed calculators" out there that take into account prop pitch, outdrive ratio, rpm, slip, etc. At some point it is all a math model. Figuring 10% slip and a 1.50:1 outdrive ratio, here's the speeds @ 5000 rpm according to one of them:
- 21" prop = 59.7
- 22" = 62.5
- 23" = 65.3
- 24"= 68.2
- 25" = 71.0
- 26" = 73.9
