Torque Lean
Old 10-25-2019 | 10:11 AM
Originally Posted by Padraig
Quote
Padraig, ive thought about this but i cant seem to get any real info on how this effects torque leverage? from what ive found a lot of cats/ semi surfacing drives do this. but with being a V hull and a relatively mild prop depth i cant find much info on it
I too have no real world experience with it but back in the late 90s many vee a hulls were being supercharged and the owners were just going up in pitch and would often experience problems. The recommendation was usually was a gear change instead of a bigger prop.
I would give BBlades a shout out.
Padraig[/QUOTE]
ill have to do some more reading
i did reach out to BBlades and he sounded pretty sure with some prop work he could get it pretty cleaned up, so ill be sending that out in a few week s
LTZCrew is offline
Old 10-25-2019 | 01:04 PM
SB
I have always heard that a different gear ratio and smaller prop was usually the cure for torque lean.
Padraig
Do you remember if it was a pitch or a larger diameter thing ? I know diameter can do some odd things, especially small lightweight boats.
SB is offline
Old 10-28-2019 | 11:15 AM
I was wondering if its a diameter thing as well, if you have less of it, it should be less leverage to roll the boat - or so i thought but i could not find any info on it
LTZCrew is offline
Old 10-28-2019 | 01:57 PM
SB
If no answers here, being a West Coast Boat, there are a handful of those Shockwave Tremor's running pretty good over at River Dave's Place.
Here is just one thread: https://www.riverdavesplace.com/foru...tremor.101747/
SB is offline
Old 11-02-2019 | 10:06 PM
did some digging on their, a couple with 565's but not much more in the wood works it seems
LTZCrew is offline
Old 11-03-2019 | 08:58 AM
Dont know if it would help but I read an article years back about a little tab you can put on the length of your skeg to prevent torque lean. RPM used it on almost all their boats.
Keith Atlanta is offline
Old 11-03-2019 | 10:42 PM
RPM? The cats being built by Lavey?
I wonder what it was or called I'll have to do some digging I know about a wedge on the skeg to avoid crap walking when running fast In a single eng boat but neve came across one for lean
LTZCrew is offline
Old 11-04-2019 | 12:57 PM
https://thmarinesupplies.com/products/torque-tab
Torque tab, but as you said, believe to counter torque steer. Never read or have any experience if they help with a list.
cheech is offline
Old 11-04-2019 | 10:26 PM
Cant seem to find any info on the list/torque lean.
LTZCrew is offline
Old 11-04-2019 | 10:38 PM
For $26 its worth a try. It cant get any cheaper or easier. It will cost more for the beer.
