Water Temperature won't get hot enough?? >
Old 10-07-2019 | 11:38 AM
  #31
Originally Posted by ThisIsLivin
You have an IR Gun, check each leg of the cross over to see if you are experiencing unbalanced flow. I have the same setup and it works perfect, although I added a -10 line from the back of the intake to the front intake cross over to bleed off any steam and to insure good water flow to the heads. I have checked my temps with a good IR gun and my temps are within 1-2 degrees everywhere. What is the water temp you are running in? I was out last weekend in 55* water and idling down the river, I barely got to 115*. Once I got to the lake and pushed it hard it warmed right up. Water temp was 155* and oil temp was 250*. Yes I know my oil cooler is a little small.
The lake temp was 58 on my last and final run.
Crossover temp was 98. Maybe 1 to 2 degrees difference from each end. Head temps are 15 to 20 degrees difference. That's not uncommon, but if yours are within 2 degrees, that's pretty good!
Because you installed a hose from front to back on the manifold to release steam pockets, did you still drill your thermostat?
Bavanew is offline
Old 10-07-2019 | 09:07 PM
  #32
tggrounds's Avatar
Yes that is correct. There must be some sort of imbalance. I have tried holes in the thermostat and different size bushings in the bypass to restrict some water. I have talked to other people that have no problem with the same setup. Don’t get it.
I just put my hand on one side of the crossover, and one side is cold and the other is hot.
tggrounds is offline
Old 10-08-2019 | 04:39 AM
  #33
Full Force's Avatar
You will never stabalize with a crossover, some guys have been able to but it's rare, my boat has had no stat and crossover since new in 1987, no issues from it... I tried to re invent wheel like you and now it's back to the way it has been, I have a max of 75 degree water temps and typically less, oil temps 180-190 AFTER cooler, why bother it seems good from factory, I will see 100 water temp maybe at best, 110 at idle after a hard run, don't mess with what works..
Full Force is online now
Old 10-08-2019 | 06:50 AM
  #34
If you want Automotive warm up times and higher temps , you will have to put on a Circulator Pump .
The water temps inside an engine , with a crossover , are very uneven at low speeds.
dunnitagain is offline
Old 10-08-2019 | 07:28 AM
  #35
I have a Stewart racing thermostat that has 3 3/16” holes in it. Based on all the threads on the subject, I think I’m one of the very few that has a crossover working well with a thermostat. Maybe it’s the extra lines I put in from the back to the front of the intake.
ThisIsLivin is offline
Old 10-08-2019 | 05:19 PM
  #36
seafordguy's Avatar
Do you have the right sender?
I just had mine on the Dyno and it proved that the builder didn't match the sender to the gauge. Just ordered new senders from CP this afternoon
seafordguy is offline
Old 10-08-2019 | 05:51 PM
  #37
I assume that it is, as the gauge correlates to the IR reading that was taken near the temperature probe.
Bavanew is offline
Old 10-08-2019 | 05:53 PM
  #38
If it's not too much trouble, when convenient, can you send me a pic of your additional manifold hose?
Bavanew is offline
Old 10-08-2019 | 07:53 PM
  #39
Sorry, just checked and I don't have any photos of the current configuration. The boat is at my Beach House which is 285 miles away. The worst part is my schedule is so busy, I won't get back up there till the middle of November. I can describe what I did, maybe that will help. I have a Brodix HV2000 intake and it has provisions to drill and tape the intake at the rear where the intake covers the water jacket openings in the cylinder heads. I had it drilled and tapped before I assembled the motor for 1/2" NPT. I installed a -10 - 1/2" NPT 90 in the those new rear ports. At the front on the intake manifold where you have your sensors, I installed 1/2" NPT T's with the side port towards the intake. I then ran a -10 line from the rear to the front and put the sensors in the front facing port of the T's. Hope this helps. All I know is that every time I check engine temps after running it hard, is they are even everywhere, front, back, block, heads. I have a hard time getting it warm when the water is real cold, anything below 60mph and it's below 150*. But once the water gets to 70* it runs right at 155*-160* at any planning speed.
Old 10-08-2019 | 09:37 PM
  #40
What! You won't drive 285 miles to take some pics for a complete stranger? Lol
Your explanation is clear. Thank you for that.
Separate from my lack of heating issue (issue to me), I like the idea of running a line front to back, it would certainly assist in balancing overall temperature between the heads, block and intake.
Bavanew is offline
