Originally Posted by LS1
(Post 4726692)
Here's some new info on the new Gen 7 Plus pump Hardin just came out with.
Advantages of new Gen 7 Plus |
Originally Posted by tbev
(Post 4726903)
Thanks flash, do you just replace impeller every year? How long with the rest of it reliably last? I'm going that route if I have the room, I'm changing from an omc to this bravo so I'm not sure where my motor is going to end up quite yet.
the johnson pumps , this will be second season,,,so,,no issues but have only 10 hrs on pumps. hope that helps........ |
(Post 4726878)
If I buy a stock pump and the $95 rebuild kit every year, should I buy the $150.00 rebuild kit (also replace the bearings) every other year?
Does that sound like the best plan? If the seal goes bad, it will allow water to get to the bearings and dirty/greasy water will come out of the weep hole on the pump. |
Originally Posted by Griff
(Post 4726946)
Not needed at all. The bearings rarely go bad unless the shaft seal goes bad.
If the seal goes bad, it will allow water to get to the bearings and dirty/greasy water will come out of the weep hole on the pump. You think you could put 100 miles on the pump once water started coming out the weep hole? I'm just wondering if I'd be able to make it home if that happened offshore. |
(Post 4726970)
Good enough, I'll probbaly have a spare with me anyways, that's another reasone I like the Johnson setup, sems like it will be a bit easier to replace the entire unit.
My stainless Hardin pump is 8 seasons old now and it has never given me a single problem or leaked a single drop. I buy the rebuild kit every year for $40 as cheap insurance. I can’t speak about the Gen 7 because mine is the Gen 4 but in my experience there is no downside. Good luck with your new boat.
Originally Posted by ph1971
(Post 4727016)
Thansk for the input, really. I was wondering if there was a better version of the Hardin pump, not necessarily the newest. Sounds like that gen 4 is great and the rebui;d kit is cheap, that sounds perfect to me. Does the rebuild kit have two wear plates or just the obe larger one? |
The kit comes with both wear plates,2 O-rings , and an impeller. Silicone grease will keep the O-ring located while assembling. The fittings are not included with the pump FYI.
I have just the SS housings affixed to the OE Merc pumps on '96 7.4LX MPI's. I've run the impellers for two seasons with zero end wear and only "wrinkling" on the insides of the impeller blades. Actually thinking about going 3 seasons on the impellers. I only buy the rebuild kits with the plates every other impeller change as I flip the plates to give a fresh wear surface to the impeller. I've seen no drop in water pressure doing this nor running the impellers for 2 seasons.
| All times are GMT -5. The time now is 06:40 AM. |
