Why do my Oil Filters get so Tight >
Old 05-22-2020, 07:53 PM
Craney's Avatar
Default Why do my Oil Filters get so Tight
I only put my oil filters hand tight, but every time I change my oil the filters it feels like Bigfoot put on the filters why is that? Filters are Wix gold 1060.
Craney is offline
Old 05-22-2020, 08:09 PM
Are you putting a light film of oil on the seal?
Trash is offline
Old 05-22-2020, 08:14 PM
Craney's Avatar
Yep
Craney is offline
Old 05-22-2020, 09:22 PM
how tight is hand tight??? ....you only need to go 1/4 to 1 full turn after the filter makes contact with the housing/ block depending on filter mfg reccomendations
speicher lane is offline
Rookie's Avatar
Received 1,207 Likes on 580 Posts
All mine do the same thing, I can't believe how tight they get. I have actually broken the remote oil filter mount removing one.
Rookie is offline
Old 05-23-2020, 01:22 AM
Same thing here. Always put them on by hand but rarely can I get them off w/o a filter wrench. Maybe the seal swells just slightly?? Seals properties change over time??
zz28zz is offline
Old 05-23-2020, 03:00 AM
Craney's Avatar
I don’t have this problem when I change the oil in my trucks.
Craney is offline
Old 05-23-2020, 10:28 AM
What oil are you putting on the o ring?
tmmii is offline
Old 05-23-2020, 11:05 AM
It would be interesting to see if it is simply the heat-soak from being in a closed engine compartment x "X" hours between changes is the actual culprit in terms of actually effecting the thin barrier film of oil or the sealing ring
Old 05-23-2020, 11:24 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Always harder to remove cold, which is when we typically change the oil in a boat.
Sydwayz is offline
