Mercruiser 420 Stumbles >
Old 06-18-2020 | 08:25 AM
Quick Update,
We through all the connections from the batteries, bus bars, engine, barrel connectors, and up to the ignition switch. All tight and complete, no corrosion. One thing I did notice is the the Port Engine is slower cranking than the Startboard engine which I will diving into next but that got me thinking about SB's comments regarding the Perko switch, I am going to pull that apart and see how it is wired. Luckily I have the complete red book to guide me. Many of my past Formulas, you could use the trim switches with the keys and the batteries OFF, but this one - the keys and the battery need to be ON for functionality. I also ran through the fuel lines and carbs, everything was clean. The last check is the fuel vent and siphon valves.
distantthunder is offline
Old 06-18-2020 | 10:12 AM
TomZ's Avatar
Really great having all that information available, isn't it?
My electrical system works just the same. I need power on for the trailer functions to work, and ignition powered on to operate the individual trim circuits.
TomZ is offline
Old 07-26-2020 | 09:39 PM
Originally Posted by SB
No crank is electrical.
Are your battery switches in positions where the two motors are tied together, by any chance ? Share a ground ?
Ignition switches share a power wire or ground ?
Any stumble/misfire when you use outdrive from or trim tabs ?
well, the issue switched back to the starboard engine. Only issue that I have noticed outside of the stumble is that the port engine is slower to crank, my cockpit speakers have become really distorted and all the gauges dip when I hit the trim switches while underway. Looks like I’m chasing a lose connection. The only thing I haven’t checked is inside of the Perko switch. I’ll be digging into it tomorrow.
Old 07-26-2020 | 10:13 PM
Rookie's Avatar
Perko switches do go bad. Most of the time they are riveted together. Just replaced on last week.
Rookie is offline
Old 07-27-2020 | 09:00 AM
Rookie's Avatar
Originally Posted by sailtexas186548
Sounds electrical to me, I would check voltage to starter solenoid cold (when it works) then when it does it again, check and see if you are getting a good 12v. If so, probably bad solenoids or grounds (clean all ground anyways, can’t hurt)
on another Note, I am building some 420 clones and there is really nothing online to reference. Could you post a bunch of pics of the 420s from all angles since you have a nice original set? Not many left out there
https://www.crowleymarine.com/mercury-outboard/949.cfm
Rookie is offline
Old 07-27-2020 | 09:15 PM
I buy from Crowley all the time never thought to look there, thanks man!
sailtexas186548 is offline
Old 07-27-2020 | 10:10 PM
Rookie's Avatar
I just refreshed 2 Merc 420's for my Panther. I did change from the stock flat tappet cams to HR 500 EFI cams. I should be able to give some feedback on performance differences compared to the stock Merc 420's in a week or so.
https://www.jegs.com/i/Crane-Cams/271/169621/10002/-1
Rookie is offline
Old 07-27-2020 | 10:15 PM
please start a thread for that, I will be able to contribute in a few months once my engines are together, would be good to have some recent 420 rebuild with currently available tech and parts, not much out there that I can find...
Old 08-21-2020 | 06:33 PM
Still battling this issue, stumble/stall still switching from port to starboard every other weekend (aka whenever it wants). Yesterday, took it out on the river and ran strong for 35 mins, parked at a beach so my son could swim for about an hour and then left to head back to the ramp and a few minutes after getting on plane, stumbled again. Shut down engines - removed carb bowl - bone dry. Restarted, removed plug on the side of the bowl - fuel level normal - ran fine the rest of the day.
Today, removed both anti-siphon valves - replaced with hose barb and will test tomorrow while I wait for replacements.
Fun new issue - keys both in OFF - turn on Panel Lights Switch - Panel lights illuminate AND my gas Gauge comes on and reads half tank. Feel good to be back in the boating game......
Old 08-21-2020 | 08:44 PM
TomZ's Avatar
We talked about the fuel gauge thing... no clue there. Ground Issues causing a funky draw?
On the fuel issue... considering it’s been with both engines, I think maybe some kind of a an issue with the tank vent and/or anti-siphon valves.
It’ll be interesting to see differences since removing them.
At least you’re not into the engines...
TomZ is offline
