2 stroke compression question >
Old 07-26-2020 | 07:51 PM
  #31
Originally Posted by mcollinstn
Yes, you are right.. Nobody makes ultralight 2 stroke outboards anymore. It's a shame. For what you describe, I would look into a powerhead or block.
Complete powerhead -
https://www.ebay.com/itm/Yamaha-Outb...-/254663384100
Above motor may have salt rot in it. I suppose you could ask the guy to pull off the exhaust chest cover and send pictures...
Or, here is a very pretty bare block. You might want pictures of the cylinders..
https://www.ebay.com/itm/15HP-63V-15...-/273383360024
That powerhead looks a little rough, especially coming from Florida. Mine was like new on the outside.
I found a new Yamaha case for just over 1000. I seen the China version. Much cheaper but I worry about the quality. The machining tolerances and also the metal quality.
underpsi68 is offline
Old 07-26-2020 | 07:57 PM
  #32
Originally Posted by oconnor marine
clean real good with brass brush and apply marinetex. Let cure and flat file. Reasemble with new gaskets
Hummm I never thought of that. I'm trying to salvage the summer and I could worry about building a new power head over the winter.
Thanks for the idea!!
Old 07-26-2020 | 07:58 PM
  #33
ive done it many times
oconnor marine is offline
Old 07-26-2020 | 08:20 PM
  #34
how does it hold up long term?
I'm also concerned the compression is low. I won't know till I put it back together.
