BBC 427 roller cam >
BBC 427 roller cam
BBC 427 roller cam
Old 12-16-2020 | 03:59 PM
GPM
its a 2 bolt block, I plan on running the stamped steel roller tip rockers to fit under the OE valve covers, Its an all stock rotating assembly with new K Black forged pistons, the heads are stock oval port closed chamber heads..............Im not trying to build a TF engine......
The stock heads won't take much lift without hitting the guides, unless you machine them. 2 bolt, cast crank and rods, guessing you'll want to keep the RPM down, maybe 228/ 236 range at .050. Just a guess
GPM is offline
Old 12-16-2020 | 04:08 PM
F-2 Speedy's Avatar
The new guides have been machined for a roller higher lift cam, Id like to spin it to 5800 to 6k if I want
F-2 Speedy is offline
Old 12-16-2020 | 04:09 PM
I want something a little more than stock, I talked to Bullet, he was in the 240-248 ?
Maybe go with a similar grind to the 427/425HP. lift on stock 390 was 461/ 480 425HP lift was 519/519 Duration on stock 425HP was "around" 232/236 but keep in mind it was a solid cam.
abones is offline
Old 12-16-2020 | 05:29 PM
i think the hp500 efi cam would be a good choice,230/236 at .050.598/610 lift 114 lsa.crane cams 169621.with the factory heads and 10.25 to 1 cr i think it will make you smile.i might have one on the shelf,if interested il check.
mike tkach is offline
Old 12-16-2020 | 05:43 PM
F-2 Speedy's Avatar
is that a step nose gen 6 ? or no
Old 12-16-2020 | 06:11 PM
GPM
The 110 lsa may be better for the street
GPM is offline
Old 12-16-2020 | 06:44 PM
yes step nose gen6.
Old 12-16-2020 | 06:46 PM
agree,either one would work.
Old 12-16-2020 | 08:25 PM
F-2 Speedy's Avatar
Ive not built one of these in years, can the step nose cam fit ? I see in the front of the block that it looks like its machined for the retainer ring but not sure
Old 12-17-2020 | 08:20 AM
F-2 Speedy's Avatar
ttt
