1993 XR6 idle stabilization/Lync and sync question >
Old 03-03-2021 | 07:57 PM
seafordguy's Avatar
Default 1993 XR6 idle stabilization/Lync and sync question
1993 XR6 on my 16 Donzi
Posted this on S&F but figured I'd cross post here....
I have followed manual to the T on the Lync and sync and want to confirm that If I've disconnected the white/black wire coming out of the idle stabilizer at the connector (which is after the switch boxes) have I truly disabled the idle stabilization feature?
I guess the reason I ask is with the wire unplugged or plugged in I get the same idle timing reading at cranking speed. Does the box advance timing at cranking speed or does the motor need to be running?
Eric
seafordguy is offline
