Slipping head bolts... better solution?
Thanks Mike. I didn’t explain it right yesterday. I was only using that as a test when it started to slip. It wouldn’t even make that without slipping on a couple of them.
My usual method...
40# start point, 50#, 60#, 70#.
To note... they’re not all slipping. Two on one side, three on the other.
My usual method...
TomZ, you used 80 grit. That article said to use 60 per ARP's recommendation.
I know splitting hairs. For the sake of clarity as to what they do actually recommend.
Did you see another recommendation from ARP to use 80?
80-grit was the coarsest I had here at home; it’s pretty rough though and thought it would be fine for the job. I guess I can get 60 and try it. I might just call ARP to figure out what the deal is.
I had the same problem you are having. Does it feel like the torque wrench is jerking? It was a problem with the threads in the block. I could not leave it alone till i pulled some of the threads out of the block. I should of gone to studs. I think the jerking is causing the washer movement.
I roll through the procedure and achieve, let's say, 50#'s. When I go to 60#'s, I apply the torque, it gets tighter, but then "gently" gives way about a quarter turn. I stop at that point. On the other engine (short bolt), this led to a broken bolt so I'm being extremely cautious. I don't want to hurt the block.
I'll get some 60-grit and try that I guess.
joking
