SBF HB bolt seized and can’t remove >
SBF HB bolt seized and can?t remove
Old 05-08-2021 | 08:41 AM
  #41
Just send me a text if your around today.
Tks
John
231-233-151three
getrdunn is offline
Old 05-08-2021 | 08:42 AM
  #42
resurrected's Avatar
Sounds like you've thrown everything normal at it, and then some. I like that inertia socket from IR, or you need a torque multiplier.
resurrected is offline
Old 05-08-2021 | 08:53 AM
  #43
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The Dewalt 20V puts out 300 lb.ft of torque. I've seen it snap ARP wheel studs in reverse with a bound up lug nut.
Buy one from Lowe's or HD and return when you are done.
Sydwayz is offline
Old 05-08-2021 | 09:10 AM
  #44
I’m going back old school with some 1 1/2” square stock this afternoon. I’ll cut a 4 footer and put all I’ve got into it after heating up again. I’m pretty certain I’ll snap off the end of the breaker bar. 🤣
getrdunn is offline
Old 05-08-2021 | 10:16 AM
  #45
Drill the head off.
Pull balancer.
Remove bolt stub.
RedBoatFl is offline
Old 05-08-2021 | 10:37 AM
  #46
You need a heavy wall impact socket and that race track air impact. Get the bolt scary hot with your torch and then hit it with that impact. Scary hot means you think its on verge of melting. You won't melt it with map gas, but try, then hit with the impact with heavy wall socket. The thin wall ones suck. Did a side by side test with cordless impact and lug nuts. Thin wall would not budge them, two different impacts. Grabbed a "impact" socket and they came right off. Never thought it made a difference, it does!
zfrilly is offline
Old 05-08-2021 | 10:48 AM
  #47
Sent a pm with details on where impact is if you’re interested in trying it
ShortCircuit is offline
Old 05-08-2021 | 10:50 AM
  #48
F-2 Speedy's Avatar
I just bought the Dewalt 700/1200 20v its a monster DCF 899............
F-2 Speedy is offline
Old 05-08-2021 | 12:47 PM
  #49
Thanks very much Gabe for the offering. We gotta meet up sometime! I just got that stubborn ***** out. 💪
getrdunn is offline
Old 05-08-2021 | 12:59 PM
  #50
Yep, its a beast. I have the same one. Puts my air impact to shame.
Griff is offline
