Mercury 500 EFI closed cooling >
Old 05-31-2021 | 03:57 AM
Default Mercury 500 EFI closed cooling
Hi
Is it possible to instal a closed cooling circuit on a MERCURY 500 EFI ?
If you have realizes this evolution, some photos, with supplier, satisfied ?
If so, lateral position feasible ?
Thanks you in advance for your leads
bajalux is offline
Old 05-31-2021 | 10:34 AM
Joe's Avatar
Joe
Offshore Cowboy
Absolutely possible. I did it on mine a long time ago, and it's even more readily available now.
Joe is offline
Old 06-21-2021 | 02:57 AM
Hi
Do you think this model MONITOR MRM-5321 is compatible on the 500 EFI
If you have this mounting pattern, how much room is needed on the front ?
On my Baja, it's very short !!
bajalux is offline
Old 06-21-2021 | 01:40 PM
**Watching as I want to do the same on my stock 502 EFI with CMI e-Top exhaust
MooresWarlock is offline
Old 07-06-2021 | 11:06 AM
Hello
Still without a solution ...
Seen in a offer in Croatia, a twin engine Mercury 500 EFI with closed cooling...
Not very pretty, but it is equiped
bajalux is offline
Old 07-06-2021 | 02:48 PM
Joe's Avatar
Joe
Offshore Cowboy
Yes. Did it on mine back in 2004-2005. Mounted the reservoirs in the gunnels, and painted them to match the engines. Worked perfectly. Use distilled water. Sorry... no pics! Boat literally sold within days after putting it back together.
Joe is offline
Old 11-04-2021 | 07:52 AM
Hello
Without aftermarket solution !!
I throught to install the parts of a 525 EFI on my 500 EFI,
but I just noticed that the heads do not have the passage of water at the exit of the heat exchanger crossover manifold !!!
Damage, that would have been simpler
Bye
bajalux is offline
