External Hydraulic Steering Hoses >
Old 06-29-2021 | 01:42 AM
Veteran: Navy
Many of us in the Tampa Bay Area go to Amazon Hose to have hydraulic hose made up. No relation to Bezos.
Give them a call and tell him what you're using it for, length and ends.
http://www.amazonhose.com/locations/tampa/
AmiableDave is offline
Old 06-29-2021 | 06:19 AM
I just replaced ours 2 years ago…I was astounded at the price of SS fittings. They were easily 2-3X more than brass. For me it didn’t make sense. I went with brass. As you stated many of the old hoses are chrome coated brass. If you want SS you have to pay to play. There are only a few manufacturers that supply them. You do realize that brass has excellent corrosion resistance qualities. Brass is probably already used elsewhere on your boat in the bilge. It just doesn’t look as fancy.
I also had a hard time sourcing the aerotec black hose that’s rated to 2200-2500 psi.
good luck
1MOSES1 is offline
Old 06-29-2021 | 08:09 AM
SABER28's Avatar
i have those hoses if you want them, just cover my shipping to you. four of them, #6 stainless fitting, about 17 inches long. let me know
SABER28 is offline
Old 06-29-2021 | 08:13 AM
Veteran: Navy
This article gives reasons why not to use Brass below the water line in salt water.
https://www.cruisingworld.com/how/down-brass-tacks/
Old 06-29-2021 | 08:34 AM
PM sent.
jtbooten is offline
Old 06-29-2021 | 10:20 AM
Dean Ferry's Avatar
I'm headed to Amazon hose tomorrow for a hose for the Skater.
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 06-29-2021 | 12:19 PM
Most of the fittings used on hyd steering hoses are brass. They are just SS or nickle plated.
Griff is offline
Old 06-29-2021 | 09:57 PM
it’s done for aesthetic honestly. We had hydraulic hoses from factory that were coated…by the time the hoses dry rotted, none of them had coating anymore. The brass was showing thru and they were fine.
1MOSES1 is offline
Old 06-29-2021 | 10:06 PM
Duplicate
1MOSES1 is offline
Old 06-29-2021 | 10:18 PM
Here were the hoses after 13 years. Maybe more…as you can see the coating was long gone.
1MOSES1 is offline
