Help boat got overheated , doesn’t run right .. >
Help boat got overheated , doesn?t run right ..
Old 07-25-2021 | 01:18 PM
I guess I will go back to mechanical pump
messed around trying to get better psi now shows 0 psi
Guitarhead is offline
Old 07-25-2021 | 01:26 PM
Why change a coil and fuel pump because of an overheat caused by a broken belt????
Griff is offline
Old 07-25-2021 | 01:35 PM
I had low fuel pressure …I checked spark because of sputtering … all my spark plugs look black and burnt up ..so decided to go ahead and change plugs and upgrade coil
Old 07-25-2021 | 01:44 PM
I think my mechanical fuel pump got damaged because block got so hot
Old 07-25-2021 | 02:06 PM
Talking
compression test or leak down..........
agree electric pumps push better than pull...
keep us posted...
good luck
flashgordon is offline
Old 07-25-2021 | 03:03 PM
keep us posted...
good luck
well reconfigured pump to push more than pull . Now I have 0psi . Think pump already messed up . Bought a mechanical pump to put back in but my rod is stuck ….calling it a day
Old 07-25-2021 | 03:09 PM
SB
Hate when my rod get’s stuck.
Paramedic or family doctor ?
SB is offline
Old 07-25-2021 | 03:18 PM
Rod is stuck? The rod that rides cam lobe and operates mech pump? If so, that would explain low fuel press.
zz28zz is offline
Old 07-25-2021 | 04:42 PM
Curious, have any info on the fuel pump such as spec, name, part number? That doesn't look like what I would consider enough to feed the BBC?
PA.WOODCHUCK is offline
Old 07-25-2021 | 04:54 PM
Rookie's Avatar
If you haven't already toasted the engine that fuel pump will.
https://www.edelbrock.com/universal-...e85-17303.html
Rookie is offline
