Livorsi Control Issues >
Old 10-07-2021 | 11:43 AM
Default Livorsi Control Issues
I have a twin engine boat with Livorsi throttle and shifter controls. Boat is ten years old, and has the original cables ( not DTS ). I realize the cables could need replacing, but here's what I'm experiencing. When shifting gears, the rubber boot around the handle at the base has a tendency to bunch up and slide with the position I'm moving the shifter. I figured that maybe the boots were getting old and not pliable, so I ordered four new ones and installed them. I even tried to apply a little bit of synthetic grease on the small edge of the boot that the shifters ride against. I'm still sometimes experiencing the same bunching problem with the boots with the shift stalk. Needless to say, it can be a problem when docking. The odd thing though, is with the boots removed, it shifts so smooth, it feels electronic! That's the part that confuses me. If the cables needed replacing, I would think I would feel some resistance with the base boots removed. Has anyone experienced this? Thanks!
Steve
509 SC is offline
Old 10-07-2021 | 01:08 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Steve, is there any corrosion on the base of the throttles/shifters that is enabling them to grip & bind up on the rubber boots?
Maybe upgrade to an arched base?
plat_control_anatomy.pdf
Sydwayz is offline
Old 10-07-2021 | 01:26 PM
bencini231's Avatar
Make sure the boots all the way seated so the bottom of the boot is seated to the shifter base. Also Livorsi suggests spraying some Aerospace 303 between the boot and shifter handle. The controls are super easy to remove and take apart for a good cleaning or inspection.
bencini231 is offline
Old 10-07-2021 | 07:45 PM
Attachment 577163
. Hi Brian, corrosion on my boat? Please!😂. I like the look of the newer base plate, looks like the rubber water/dust seals are built in. I wonder if they would adapt to my controls?
Bencini, this is on a 33’ AT, are you familiar with them?😂
509 SC is offline
Old 10-08-2021 | 08:22 AM
bencini231's Avatar
Funny you should ask if I am familiar with those, lol. I took my old ones completely apart and refinished them and then sold them to a friend for his 32 AT. Now I have the new style and once I got them I decided to change the shifters & throttles to a different pattern. I can say the new ones are much easier to disassemble as the top plate is separate and the older ones have the top plate in individual sections of the controls. I have Mike's number and email Livorsi Marine if you want to reach out to him. They've been great to work with for me for several years with different things.
