588 Blower Motors Cam Choice
454 is 4” stroke 4.25 bore
496.(not factory gen vii) is 4.25 stroke 4.31 bore
502 is 4” stroke 4.47” bore
540 is 4.25” stroke 4.5” bore
556” is 4.375 stroke 4.5 bore
572 is 4.375 stroke 4.56” bore
572 is 4.5 stroke 4.5 bore
598 is 4.5 stroke 4.6 bore
Lift is .704 net - 114 lsa. Spec’d to peak @ 6k and carry to 6,300. Heads flow approx 10-15 % more than the promaxx 340 cnc version. Should make 750 @ 6k. Possible more if the heads perform well allowing to peak out at 6,400 and carry from there.
You should have a torque monster with those heads - int runner. The lobe family from comp that icdedppl used would something to consider especially if your going SC. I’d just step up the duration a few degrees with your stoke and CI. Or the same. With superior flowing heads you can ease on the duration and let the heads do the work.
ck out icdedppl’s threads on his 548’s.
A 540 with a 1071… 900 hp all day long.
Just went back to OT. Mega blower great blower but personally wouldn’t put on anything much more than a 502. But yes I get it…. All comes down to lots of $$$$
