Crower shaft rockers? >
Old 01-24-2022 | 01:03 PM
  #41
Originally Posted by GPM
Has anyone ever seen a broken steel rocker ?
Personally being into hi performance since I could drive and having both I’ve never broke either. Not saying won’t happen but…. Broke a some rocker studs but not rockers.
getrdunn is offline
Old 01-24-2022 | 01:20 PM
  #42
GPM
I had a couple aluminum Jesels brake, just cruising along, made a mess out of things.
GPM is offline
Old 01-24-2022 | 01:32 PM
  #43
SB
^^^^^Yup, then we have Dart’s blocks oiling issue w rear cyl’s, Morel’s typical oiling issues, and then……,
SB is offline
Old 01-24-2022 | 02:44 PM
  #44
Ive seen aluminum break many times. 670-715 lift range average
47EXCALIBUR is offline
Old 01-25-2022 | 01:35 PM
  #45
My Harland Sharps arrived today. We’ll see how they work out. I haven’t weighed one yet however they seem heavier than they use to. These are the later ones that have some geometry changes to help complement the aftermarket heads. Intakes and exhaust are a little different.
getrdunn is offline
Old 01-25-2022 | 02:14 PM
  #46
So there is a reason why they make different levels of lifters, kinda like why they make different levels of crank shafts. If your building a 500 HP style engine do you need a Sonny Bryant Crank, top dollar bullet proof rods, Steel shaft rockers, etc. probably not. If you have a mild cam and correct Valve spring pressure and correct geometry, you don.t Need super strong expensive rockers. Rocker arms seem to take the beating if other components in the valve train are not correctly matched, too much spring pressure lifter float etc. the rocker being the fulcrum point gets constantly slammed. Now if you are building a High HP high RPM engine with a radical cam, then absolutely go with steel Rocker arms. My point is that each build can require specific components, and not all need the top shelf parts. can get very expensive very quickly
abones is offline
Old 01-25-2022 | 02:40 PM
  #47
Yeah kinda like we all know all the top shelf good guy parts are and I can build a heck of an engine with all but then I wake up and come to my own reality. Everything and anything can and will brake under the right (wrong) circumstances. To be honest I had to call back after I ordered the rockers to ask what the price was. Couldn’t believe I forgot to ask but I did. Not as pricey as the steel crowers but a little higher than most others. I was going for the best fitment and bang for the buck as well as the best customer service. Not being able to confirm part number for my app and the unknown delivery date shaft rockers became out of the question this go around. I don’t know if any other rocker arm manufacturer that has worked with aftermarket head companies etc to manufacture a better fitting rocker. Not implying their the best by any means but their here and awaiting install as manufacturing and delivery are huge issue with many parts. Like smitty and others have said don’t wait on anything you think you might need. Get it or order it now. Problem with paying and ordering is there’s rarely a certain timeframe on delivery. I’ve been hearing a lot of 4 to 6 months but could be longer. Sucks
getrdunn is offline
Old 01-25-2022 | 02:56 PM
  #48
F-2 Speedy's Avatar
I dont get this, Ive run the same rockers on AFR, DART and the Mercury 525........so now you have to make sure what valve you put them on..............
F-2 Speedy is offline
Old 01-25-2022 | 04:05 PM
  #49
I think you hit the nail right on the head. The biggest thing is being honest with yourself on what you expect from your engine. Thats why some can get 400 hrs out of their 525 efi and some not even 200 hrs before failure. The biggest problem is heat and cycle time.
KWright is offline
Old 01-25-2022 | 04:08 PM
  #50
Some of the newer heads have the valves moved slightly. So yes the rockers will not be the same as stock.
KWright is offline
