Mercruiser 350 cam selection
On a cast iron head nothing happens fast , trust me you'll be most of a day with the grinder. You're not really reshaping just cleaning up some material the accountants told the engineers to not worry about. Go to a machine shop and get a cracked cylinder head and give it a shot.
Sorry to the OP, many of us are retarded and get worse during the winter.
Here is one if several threads on subject:
2004 350 MAG MPI cam, ecm upgrade?
You will need minimum better valves springs and pcm programming.
If your boat is heavy and slow, this may not be worth it. If boat is already quick , you will see some gains.
