KN 3002 filter
At the top of the KN filter is a welded on nut that helps in removal. There are two little pass through holes on the removal nut.
Does anyone know what the reason is for the holes? Is it some safety reason?
Further more….That nut doesn’t let you, well, help you, take off filter either. Nut seems to be a gimmick. , but good news is the K&N filters are really good. Thick shell, good filtration, good flow rates. 👍
You beat me to it on the nut, yes, more of a gimick as far as loosening one thats tight!
I disagree, I have always found the nut on the K&N usefull. On my Yukon XL the oil filter is underneath the engine and besides need to crawl underneath the engine the filter is in a recess. It is difficult to get a filter strap on. The nut on the K&N works fine. I use a socket and ratchet. That being said...I don't over tighten it.
Padraig
Padraig
