Fuel Pressures while running - 502 Mag MPI >
Old 06-09-2022 | 04:15 PM
  #31
Veteran: Army
If it were me Id ditch all the cool fuel stuff and replace it with a good high volume pump and regulator, thats what I did on my Outlaw also got tire of the vap lock with cool F
I'm not opposed to that idea. Would love it if someone could post some part numbers so I don't waste money on the wrong stuff.
DrFeelgood is offline
Old 06-09-2022 | 04:28 PM
  #32
F-2 Speedy's Avatar
check out the 496 cool fuel bypass thread
F-2 Speedy is offline
Old 06-09-2022 | 04:30 PM
  #33
Veteran: Army
Just saw that. Thanks, will keep that in mind if no other explanation arises after Diacom runs.
Old 06-09-2022 | 04:38 PM
  #34
F-2 Speedy's Avatar
some one else on here had low fuel psi or loss of power and it ended up being the fuel lines from the tank pickup to the fuel separator, the lines were collapsing internally,
Old 06-09-2022 | 04:40 PM
  #35
Veteran: Army
Replaced pickups and lines from pickups to separators last week, no improvement. Also took out 90 degree fittings.
Only thing I haven't done is lines from separators to fuel pumps.
Old 06-09-2022 | 05:33 PM
  #36
F-2 Speedy's Avatar
I have a couple used fuel pumps if you want to try them, changing them is a PITA one of mercury's better idea........
Old 06-09-2022 | 06:14 PM
  #37
Veteran: Army
Thanks. Will keep that in mind. Stbd Pump replaced with aftermarket already, and new OEM regulator, still behaves exactly like Port. PITA for sure - did not enjoy the experience!
Old 06-09-2022 | 06:28 PM
  #38
F-2 Speedy's Avatar
I must of missed a bunch of this.......... always late to the party
Old 06-11-2022 | 08:44 AM
  #39
Veteran: Army
Did a Diacom run this morning. Connected to Stbd motor. Learned that my AutoMeter tach is off by a couple hundred RPM. Presuimably both tachs are off by a similar margin.
The ECM is showing me just barely tickling 4800 rpm whereas the tach is just barely indicating 4500-4600.
Diacom recorded no knock retard.
Ignition advance is 36-39 degrees at wide open.
Throttle position is indicating 99% when wide open, despite only reaching 81% with Key On/Engine off. Voltage difference of 5V reference when running?
MAP sensor at 4.92V at WOT / max rpm
Injector pulsewidth 8.5ms at WOT/max rpm.
So, I'm led to believe at this point that I'm over propped by a bit based on current HP levels, but perhaps someone more knowledgeable could look at the datalog and see if there's anything indicative of a reason for being down on power?
Old 06-11-2022 | 08:10 PM
  #40
articfriends's Avatar
stock tune? quite alot of timing, even for a hot tune!
articfriends is offline
