Lifting hatch throwing two codes (700 SCI) >
Old 06-17-2022 | 09:42 AM
Smile
Originally Posted by SB
$10 they are wired to dash. Notable example: I worked on a crownline earlier that would instantly ‘overheat ‘when you raised the hatch. Lol. It just peggedthe temp guage, but stil. It’s just too much if an smp draw ftom the dash. Installed relay at hatch motor and grabbed power/ground from battery. Real benefit was the hatch now opened much faster too.
You nailed it power from dash and was pulling power some how threw the trim sensor on the Vessiel Veiw that trim works off of a 5 volt reference just like the tps. Unplugged trim sensor back by the motor draw on the TPS sensor 100% gone!! I will rewire the correct way with relay!
Thank you very much guys!!
skydog is offline
Old 06-17-2022 | 09:46 AM
SB
Just making sure you saw the write up (uses 2 relays) I linked.
SB is offline
Old 06-17-2022 | 10:25 AM
I will check that out for sure!
Thank you!!
skydog is offline
Old 06-17-2022 | 04:23 PM
Rookie's Avatar
Thank you!!
That's why I use the inexpensive solenoid I linked.
Rookie is offline
Old 06-18-2022 | 11:54 AM
SB
:thumbs
I will prob try it next hatch i have to do. Easier is easier.
SB is offline
Old 06-19-2022 | 09:51 AM
Rookie's Avatar
:thumbs
Yes easier, but I'm also lazy... lol
Rookie is offline
