Need some ideas - port engine noise >
Old 06-21-2022 | 07:42 PM
  #31
seafordguy's Avatar
Originally Posted by Sydwayz
Billy had more than one valvetrain issue with those motors. If you can't narrow it down on the outside, pull the valve covers off and look for issues.
Yeah - I corrected some of that last year when I put steel Jesel rockers in and custom Trend pushrods. I pulled all 4 VC’s last weekend when I first had the problem and checked everything. Didn’t see any issues. That was my first thought because I ran it several times last year on 7 cylinders!! I must have missed tightening down a rocker to a stand and it worked loose! Pushrod came out and ended up in the lifter valley unharmed!! I have no idea how I got away with that, but bought fresh rocker and reassembled. Was able to pull the pushrod out of a oil drain notch in the head!! Fiasco.
seafordguy is offline
Old 06-21-2022 | 08:30 PM
  #32
Rookie's Avatar
Broken valve spring? Rockers, burnt valve? Leak down?
One of the only times I had backfire through carb was when I have a rocker stud pulling out / loosening exhaust side.
Just throwing out ideas.
Rookie is offline
