496HO Down on power
#101
I've considered it. Can't you use a timing light to do the same thing? Just curious.
Thanks. Brad.
(947)545-8991
#103
A timing light will flash when any spark is detected , a tester let's you see a spark to help determine the quality. Some more expensive ones are adjustable requiring the ignition to jump larger gaps to troubleshoot weak ignitions.
SB (08-02-2022)
#104
#106
Offshorejojo,
I would never be so bold as to say it wasn’t possible, but I’m pretty sure I had them on solid.
Plus, I think it would be a pretty strong coincidence that the two potentially problematic cylinders should be the same two that I failed to connect with wires correctly on.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
OFFSHOREJOJO (08-02-2022)
#109
are you getting miss fire codes on the scanner ?
#110
